96 Ek, alternator wont charge...
Old Jun 27, 2005 | 04:53 PM
SuicideSlide's Avatar
Default 96 Ek, alternator wont charge...
96 EK with OBD1 swap. Alternator wont charge any more for some reason. What to check? Is there a fuse?
Old Jun 27, 2005 | 05:12 PM
Capt. Jimbo McSubipants's Avatar
Default Re: 96 Ek, alternator wont charge... (TurbLu)
yep there's a fuse...i have an obd1 swap as well....crusin home one day....boom no speedo or charging goin on..i looked at my fuse's....and there is a fuse called SPD/ALT...and i'm sure yours is blown...it may be something else...but check that
Old Jul 22, 2005 | 06:05 PM
blackie's Avatar
hey delteg were your lights dimming and then your car eventually die out?
Old Jul 23, 2005 | 10:10 PM
RAWB's Avatar
If the Fuse is okay, you can also get a multimeter and see what your alternator is putting out- should be like 14.1v - just read it across the battery while the car is running. If your reading is lower than battery voltage(12v) then you'll never charge the battery.
Ekzc91
10
Jan 11, 2010 10:42 AM
lmike6453
Jan 16, 2009 06:55 PM
Cras-Delsol
Jul 16, 2008 05:59 PM
Cras-Delsol
Jul 15, 2008 09:48 PM
akteamster
Jul 20, 2004 11:13 PM
