newbie question on B16a
When you usually buy an oil filter, belts, or any parts like that, you usually go to the auto store and find an oil filter or any belts made specifically made for your engine. How would it be for a JDM B16a1? I know I just can't go into autozone or whatever and ask if they have this and that for a JDM engine, or can I?
My JDM B18C (GSR) uses the same oil filter as my stock DX motor, and it is also the same filter out of the USDM B18C1. For JDM motors things like oil filters, timing belts, etc you can use the USDM equivalent. B series VTEC motors use most of the same replacement parts anyways.
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1024595</TD></TR></TABLE>
DONT use 99 civic si if you have a 1st gen b16 use del sol b16, i noticed 99 si has differnt timing belt and tensioner part #'s than the del sol i know the del sol stuff fits because i have changed them
Thanks a bunch for the link
Sure..
Welcome to Honda-Tech
If you are still in the process of installing it,
Check the FAQ post at the top of this forum..
There are several links that you might find helpful..
