good way to torque cam gears?
Old Jun 27, 2005 | 12:30 PM
lsvtec101's Avatar
Default good way to torque cam gears?
how do i hold the cam while torquing the cam gear bolt? Thanks
Old Jun 27, 2005 | 01:30 PM
n1mr0d's Avatar
Default Re: good way to torque cam gears? (lsvtec101)
Put the timing belt on and have tension on the belt so that they can not turn while torqueing them.
Old Jun 27, 2005 | 03:14 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The B16 head has small holes that you can insert a punch
through the camshaft holders into the cams to lock
into place..
Old Jun 27, 2005 | 03:19 PM
lsvtec101's Avatar
Default Re: good way to torque cam gears? (88DXCRX)
hmmm never noticed that on the b16 si heads but have seen that on b18b heads.
Old Jul 19, 2006 | 08:15 AM
GR_DC2's Avatar
i know this is an old thread, but can someone chime in on other ways to do this? or is using the punch the best way to secure the cam gear from moving when torquing it?
Old Jul 21, 2006 | 12:20 AM
Scott_Tucker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec101 &raquo;</TD></TR><TR><TD CLASS="quote">how do i hold the cam while torquing the cam gear bolt? Thanks</TD></TR></TABLE>
If there is sufficient space between lobes and/or journals it is acceptable to put a pair of vice grips on the shaft. Put a rag in the jaws and use the minimal amount of pressure needed to keep the shaft from spinning. Make sure it does not spin or you will chew up the shaft.
Old Jul 21, 2006 | 04:02 AM
-Kirk-'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">The B16 head has small holes that you can insert a punch
into place.. </TD></TR></TABLE>
This has worked on several occasions for me and I believe is the correct way of doing it. Make sure the motor is at TDC and the holes should line up.
Old Jul 21, 2006 | 06:05 AM
AllMotorRandy's Avatar
Default Re: good way to torque cam gears? (-Kirk-)
one of the best tools ever invented!!!
kornerk12
Dec 5, 2008 11:48 AM
integlstrike1
Aug 13, 2006 07:45 AM
Po0r LiTTle CoUpe
Aug 3, 2006 08:16 PM
pwrofdrm
Jul 24, 2004 09:23 PM
Luserkid
Mar 27, 2003 09:03 AM
