VTEC doesn't engage
ok i put a new head on my type r from a 2000 civic si fully built head valve job blah blah blah anyways i put it on this weekend and i have no vtec i have oil pressure tested out the solenoid and that works cause you can hear it click no check engine light nothing what do yall think what other things mechanical that it would make it do that my friend blew his motor he threw a rod but i dont think that would have anything to do with it let me know what you think
it seem eerrbody have VTECH problems lately ... get this JDM amber one .. its badass ..
btw, longest sentence ive ever seen ... i had to catch my breath after i was done reading
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typerses »</TD></TR><TR><TD CLASS="quote">ok i put a new head on my type r from a 2000 civic si fully built head valve job blah blah blah anyways i put it on this weekend and i have no vtec i have oil pressure tested out the solenoid and that works cause you can hear it click no check engine light nothing what do yall think what other things mechanical that it would make it do that my friend blew his motor he threw a rod but i dont think that would have anything to do with it let me know what you think</TD></TR></TABLE>
Civic forum? Hybrid forum?
maybe there should be a vtech forum...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typerses »</TD></TR><TR><TD CLASS="quote">AIGHT DAMN I PUT VTECH INSTEAD OF VTEC SIMPLE MISTAKE GUYS LETS GROW UP </TD></TR></TABLE>
Try plugging the cord in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote"><-- still the ripe old age of 9.
Vtech
roffles...
Something OT: http://picard.ytmnd.com
Vtech
roffles...
WIRE IS PLUGGED IN BUDDY IF YOU READ IT YOU WOULD SEE THAT I DONT HAVE A CHECK ENGINE LIGHT. SO THERE FOR IF IT WASENT PLUGGED IN THE CHECK ENGINE LIGHT WOULD BE ON
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr341 »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typerses »</TD></TR><TR><TD CLASS="quote">WIRE IS PLUGGED IN BUDDY IF YOU READ IT YOU WOULD SEE THAT I DONT HAVE A CHECK ENGINE LIGHT. SO THERE FOR IF IT WASENT PLUGGED IN THE CHECK ENGINE LIGHT WOULD BE ON </TD></TR></TABLE>
OHH HELL NAH!!!! HAHAHAHAH
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typerses »</TD></TR><TR><TD CLASS="quote">WIRE IS PLUGGED IN BUDDY IF YOU READ IT YOU WOULD SEE THAT I DONT HAVE A CHECK ENGINE LIGHT. SO THERE FOR IF IT WASENT PLUGGED IN THE CHECK ENGINE LIGHT WOULD BE ON </TD></TR></TABLE>
Just to be sure:
You're putting a Si head on your Type R?
Is this a USDM R motor? The oil pressure switch in the vtec solenoid might be not working right, even if your oil pressure is good.
Just because the solenoid clicks, doesn't mean for sure it's moving completely. It's a good sign though, try cleaning it out or swapping with the one from your old head?
If you have no CEL, and no VTEC, it almost has to be the VTEC oil pressure switch or the solenoid is sticky (but not burned out if it clicked.) Dbl Ey! in this forum had it happen recently, or was it Wai... anyhow it's not uncommon, swap solenoids with someone and try again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote">it seem eerrbody have VTECH problems lately </TD></TR></TABLE>
*** nuts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr341 »</TD></TR><TR><TD CLASS="quote">maybe there should be a vtech forum...</TD></TR></TABLE>
Dillhole.
owned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Vtech </TD></TR></TABLE>
old.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr341 »</TD></TR><TR><TD CLASS="quote">Try plugging the cord in </TD></TR></TABLE>
Keep your hands off my cord.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 »</TD></TR><TR><TD CLASS="quote">Something OT: http://picard.ytmnd.com
I ain't clicking it! No way. It probably links to zerosearch or logout.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K »</TD></TR><TR><TD CLASS="quote">OHH HELL NAH!!!!</TD></TR></TABLE>
Haha, yeah owned again.
Another two things--
Search archived topic titles for "engaging", there's 111 results about half are about VTEC engaging.
If your VSS isn't connected (speedometer not working) you won't get VTEC.
If you're not moving, you won't get VTEC.
If you're not warmed up you won't get VTEC (duh).
VTEC Solenoid screen could be clogged.
Coolant temperature sensor could be busted. (Should get CEL though).
I REALLY hope that you had the head disassembled and cleaned before you put it on your block!!!!! When a motor blows for a number of reasons there is alot of shavings and fragments that flow everywhere oil does! You could very well have a "gummed up" head , and pressure switch to where it does not see the proper amount of pressure. Also you could EASILY shorten the life of your crank and rod bearings!!!!
