if you think you know b16a1's?
if any honda nut knows, what should the fuel pressure and or volume be for a b16a1 in a crx. also do i need to replace my stock fuel pump, out of my dx because its a bigger motor thanks for lookin
i thought the number 49psi came to mind. And a stock Fp will be enough unless you are running FI like stated above. But then again you would run higher CC injectors, needing even more fuel. L8z
do i need an adjustable fuel pressure reg. if im running walbro 255lph with stock fuel rail on turbo
92gsrteg
Aug 25, 2005 11:00 PM
iBrandon
Feb 17, 2005 02:33 PM
