'88 LXi BALL JOINT REPLACEMENT
Old Jun 26, 2005 | 06:06 PM
RAYThOM's Avatar
Default '88 LXi BALL JOINT REPLACEMENT
Hi All! I am planning to replace the driver side upper ball joint on my almost "classic" Coupe. The part I bought has the ball attached to the control arm. Is this a straight up replacement -- just removing the bolts -- or is some kind of strut/spring compressing necessary? Obviously, I don't want to get into a driveway job that I can't complete. What can you tell me? Thanks. Ray
Old Jun 27, 2005 | 07:51 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: '88 LXi BALL JOINT REPLACEMENT (RAYThOM)
Check a manual, from there decide if you can do it in your driveway or not.
Old Jun 27, 2005 | 08:05 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RAYThOM &raquo;</TD></TR><TR><TD CLASS="quote"> Is this a straight up replacement -- just removing the bolts --</TD></TR></TABLE>
Pretty much an easy replacement if you have the complete arm assy.
Old Jun 27, 2005 | 08:10 AM
Vanilla Sky's Avatar
in-and-out procedure. just watch out for stuck bolts, and have a picklefork for the upper ball joint seperation. that's the only way i've been able to get them free.
the only way these can be replaced is by replacing the entire arm. it's one piece, and it can't be taken apart.
Old Jun 27, 2005 | 08:27 AM
Chiovnidca's Avatar
Default Re: (Vanilla Sky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vanilla Sky &raquo;</TD></TR><TR><TD CLASS="quote">
the only way these can be replaced is by replacing the entire arm. it's one piece, and it can't be taken apart.</TD></TR></TABLE>
They can be taken apart, I used to replace the bushings in them. Honda sells the arms and bushings seperate if you want to get off a little cheaper.
Old Jun 27, 2005 | 08:46 AM
v4lu3s's Avatar
RTFM
i would remove the nut holding the balljoint on, then take a lrge hammer and whack the knuckle just below the balljoint it usually pops right out.
tyhen remove the 2 anchor bolts that hold the arm in, and put the new arm with ball joint in it a,d bolt it all back together.
Old Jun 27, 2005 | 09:28 AM
the bushings aren't what i was referring to. i was referring to the fact that the upper control arm and the upper balljoint can't be seperated.
Old Jun 27, 2005 | 09:34 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vanilla Sky &raquo;</TD></TR><TR><TD CLASS="quote">the bushings aren't what i was referring to. i was referring to the fact that the upper control arm and the upper balljoint can't be seperated.</TD></TR></TABLE>
Old Jun 27, 2005 | 12:54 PM
RAYThOM's Avatar
Default THANK YOU!
After comparing the replacement part against what's on the car PLUS what's been mentioned here I think I can handle this repair with minimum difficulty. My major concern was that I might have had to compress the spring but I see that's a non-issue. Thanks. I'll Be Back! See ya' Ray
blueBB4lude
11
Jul 30, 2009 09:14 AM
driftam1
10
Jul 28, 2008 07:05 AM
90CivicDaily
Jun 4, 2008 04:39 PM
Spoon
Jun 7, 2006 07:14 AM
speedsohc93
May 20, 2003 08:29 AM
