Clutch disengagement issue
Old Jun 26, 2005 | 01:42 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Clutch disengagement issue
Alright, my car was originanly an automatic and it was converted.
Here are my issues, I bled the clutch line perfectly, however these are the issues.
I press on the clutch pedal and the clutch disengages while i release 1cm away.
I know it is probably a bad clutch master cylinder, BUT can it also be that I am using a different clutch line, possibly an integra one that is too long for the civic, thus why my master cylinder isn't powerful enough to move it far enough?
Old Jun 26, 2005 | 01:54 PM
james p.'s Avatar
Default Re: Clutch disengagement issue (MugenHonda)
free bump for a good question which I can't answer
Old Jun 26, 2005 | 02:40 PM
nub.96ek's Avatar
Default Re: Clutch disengagement issue (james p.)
Have you checked the slave cylinder?
Old Jun 26, 2005 | 03:12 PM
MugenHonda's Avatar
Default Re: Clutch disengagement issue (nub.96ek)
yeah that works fine, i am positive
it has to be either its a bad clutch master cylinder or the line is too long
Old Jun 26, 2005 | 04:16 PM
sicones's Avatar
It’s not the lines, for all intent and purposes the integra hydraulic clutch system is identical to the civic, check to see if the master cylinder or slave is leaking if not your clutch pedal travel distance is off, probably from the swap it was changed. It needs to be adjusted…
Old Jun 26, 2005 | 04:58 PM
MugenHonda's Avatar
Default Re: Clutch disengagement issue (sicones)
thanks, figures, on my way to the junkyard
MugenHonda's Avatar
is it hard to take off the clutch master cylinder?
is it a pita?
Old Jun 27, 2005 | 07:46 AM
sicones's Avatar
is it a pita, not really 2 bolts and a pin under the dash and pull it out
Old Jun 27, 2005 | 08:00 AM
senpai's Avatar
I would try the simple things first: like adjusting the clutch pedal which changes the engagement point
MasterLink4253
Jun 9, 2014 07:22 AM
Miracle11
Feb 13, 2011 06:38 PM
hannslebo
Oct 8, 2009 04:44 PM
s1ngle
13
Sep 21, 2005 12:01 PM
g00se
Mar 8, 2004 06:11 PM
