Main relay clicking fast
Old Jun 26, 2005 | 08:26 AM
shreddinryguy's Avatar
Default Main relay clicking fast
Yesterday I had my car running good adn then today when i went to start it the fuel pump would turn on but then the relay would start clicking really fast and start vibrating. Could my main relay be bad?
Old Jun 26, 2005 | 01:39 PM
PrettyLude's Avatar
you might have a bad grounding problem, check the grounds near the thermostat housing to make sure its on tight, and that no rust is right there
Old Jun 26, 2005 | 02:03 PM
drdisco69's Avatar
Default Re: Main relay clicking fast (shreddinryguy)
Also check that the battery isn't dead. The starter relay is located in the main relay, and it will occillate if the voltage drops too low when starting. Give it a jump and see.
spens 91 Ef
Jun 17, 2015 12:25 PM
peteyparado
Feb 9, 2014 07:38 PM
Kidnkorner
Apr 4, 2010 08:54 PM
triple_s1x
Feb 27, 2005 11:10 AM
DIY_Racing
Feb 23, 2003 10:48 PM
