Difficulty shifting after clutch install
Old Jun 25, 2005 | 09:26 PM
sykotic's Avatar
Default Difficulty shifting after clutch install
Ok, the clutch engages fine and everything seems to have gone well, my issue is that now it seems alot harder to shift, like it takes alot more effort to move the shifter, it feels like im having to force it through something. It doesn't grind even in high rpm shifts, its just that I can't really shift quickly because it takes so much effort to get it into gear, primarily 2nd gear.
What can I check that might have been messed with in the clutch install? Could the tranny fluid being low cause this? I was thinking maybe the shift linkage? Throw out some things for me to check, for now I plan on doing a full tranny fluid flush to see if that will help, what do you guys think?
Old Jun 25, 2005 | 10:07 PM
sackdz's Avatar
Default Re: Difficulty shifting after clutch install (sykotic)
after the car is fullly warmed up, jack up the car and see if the wheels spin when the tranny is in gear but the clutch is depressed. if so the clutch isnt disengaging all the way making it difficult to shift.
Old Jun 26, 2005 | 08:56 AM
sykotic's Avatar
did that, no wheel spin, what do you suggest next? I am gonna change the tranny fluid to motor oil, I think they put syncromesh in. I'll let you know how that goes but in the mean time could you suggest some more tests?
Old Jun 26, 2005 | 09:30 AM
Slow ass EF's Avatar
overtighten the shift linkage?
Old Jun 26, 2005 | 09:34 AM
mmuller's Avatar
Mad Scientist
Default Re: Difficulty shifting after clutch install (LSVTECJay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTECJay &raquo;</TD></TR><TR><TD CLASS="quote">overtighten the shift linkage?</TD></TR></TABLE>
Old Jun 26, 2005 | 11:56 AM
sykotic's Avatar
Default Re: Difficulty shifting after clutch install (mmuller)
I was lookin at that while I was under there and it does seem like it was over tightened, i'll redo it here in a few, it takes so damn long to refill that tranny with a tiny tube, i'm changing my oil and my oil return line to a stainless steel braided line so it'll be a few before I can get to drive it.
Old Jun 26, 2005 | 02:03 PM
sykotic's Avatar
Well they did overtighten the nut/bolt that hold the shift rod to the short shifter, the bearings were crushed in a little bit by the washers, I took the bearings out and they wouldn't spin at all... got some wd40 out and a hammer and they spin now but it's real notchy feeling, packed some grease on them and reinstalled loosely, it feels better now but I haven't taken it for a test drive because I'm waiting on some thread lock to dry on my oil return line before I go for a test drive. Any idea where I can get the bearings for a skunk2 short shifter?
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
DubyaAye
Sep 22, 2004 06:23 PM
NYCz DA9
Jul 31, 2004 10:59 PM
NYCz DA9
Jul 16, 2004 04:38 PM
VTECRaZeR
May 30, 2004 02:39 PM
