Surging, steady throttle and idle
Old Jun 25, 2005 | 06:09 PM
UNKNOWN_MEMBER's Avatar
Default Surging, steady throttle and idle
Ok i'm throwing code 14, iacv and code 6, water temperature. I don't know why i'm throwing code 6 when the temperature guage works. But code 14 is a mystery. I cleaned out the iacv too. Here's the problem, when i give it steady throttle like about 10% it surges. Like it's struggling, and when i'm driving and give it 10% throttle it hesistates. I changed the rotor, cap, ignitor, and coil. Same thing. I unplugged the iacv and funny thing is, nothing happened, idle is still the same. Didn't drop or stay steady or whatever. Here's a video of idle then my giving it 10% steady throttle. Also when I just give it more than 10% throttle it's OK. It doesn't struggle or anything. http://www.geocities.com/teamo...0.MPG
Old Jun 25, 2005 | 07:01 PM
Tad's Avatar
Tad
maybe you just need a new iacv
Old Jun 25, 2005 | 07:18 PM
D@nnY's Avatar
Default Re: (Tad)
the idle air control isnt closing...isnt working .... also if your having a coolant issue (code 6) and coolant flow into the iac.... also make sure theres isnt any air in the coolant system....if oyu have a fast idle valve check to see if thats closing also
Old Jun 26, 2005 | 01:32 AM
Is that what's causing the surging when pressing the gas? How can I check to see if the iacv is closing and the fast idle valve? And for the heater hoses, is it koo to just recurclate it?
Old Jun 26, 2005 | 04:26 PM
Default Re: (UNKNOWN_MEMBER)
bump, come on guys share your inputs
Old Jun 26, 2005 | 06:17 PM
Swapped out iacv with a working one and same thing. Took fitv out to check if it was loose and it was still screwed on.
Old Jun 27, 2005 | 08:15 AM
Ok fixed the codes. Problem was wrong plugs. Now it still surges. So i cleaned the iac just incase again. made sure the fitv was tighten up and still surges.
i.
49
Feb 17, 2014 12:53 PM
99GreenEX
12
Feb 22, 2008 09:54 AM
Problemo
Jan 29, 2006 04:16 PM
urnotfast
May 20, 2005 04:36 PM
