ls b18b1
Old Jun 25, 2005 | 06:04 PM
jonathan13's Avatar
Default ls b18b1
im buying a 94 civic with a b18b1 integra motor.. i was curious how do i convert that to a vtec??.. and if i do, when i buy parts in the future do i still buy them for the b18b motor or for the b18c since it would be vtec.
Old Jun 25, 2005 | 06:20 PM
jonathan13's Avatar
Default Re: ls b18b1 (jonathan13)
also i was wondering about a turbo.. i have read on some posts about "building" the block so it can handle the boost.. im sorry im a newb and have no clue what this means.. does it have to be done? also i have read u need new fuel injectors and a couple more things for the turbo to work.. any help is greatly appreciated!
Old Jun 25, 2005 | 06:27 PM
jonathan13's Avatar
bump
Old Jun 25, 2005 | 06:31 PM
98b18black's Avatar
search...ls/vtec....it might do you some good
e jay one's Avatar
have you tried searching ever? you can put a vtec head on your ls its called an lsvtec search it. you can use a b16 or gsr head but its more complicated than just slapping a head on there. since you dont know too much about honda motors i sudjest you just leave the motor non vtec and turbo it. again search you can learn alot. building the motor means useing stronger internal parts that will benifit to a tubo set up.
Old Jun 25, 2005 | 06:33 PM
98b18black's Avatar
Default Re: ls b18b1 (e jay one)
You could have also asked this in the integra forum...considering the motor is from an integra...but you should have used the search option first....
SpydiR's Avatar
if you have an LS, slap a b16 or b18c head on it and you've got vtec. you're going to need a dowell kit [golden eagle makes them, I think skunk2 does too, not sure tho], an oil line, you'll have to tap your oil pan, prolly get a new ECU or have yours chipped. when you buy parts in the future, buy them for the application. head parts? get b18c or b16. block parts? get LS stuff. as far as the turbo stuff goes, you'd better hang around the FI forum and start reading. when people start talking about building blocks, they're talking about forged rods and low comp pistons, maybe sleeving the block, balancing/blueprinting, etc. I don't know sh*t about b-series, but I hope I helped ya out a lil
Old Jun 25, 2005 | 06:36 PM
jonathan13's Avatar
thanks for all the info.. sorry i didnt search it first.. but thanks again everyone
shady 5th
Feb 25, 2004 04:36 PM
CivicHb04
Dec 10, 2003 05:20 PM
kev tec96
Sep 23, 2003 05:24 PM
90A1TEGGY
Jul 19, 2003 01:01 PM
IlL Te GeE Ie
Jun 19, 2002 11:28 PM
