Spoon mirror step-by-step install?
i was wondering if anyone had or could show me a step-by-step install for spoon mirrors. i've searched and found a couple of things but i do way better with pictures then with just words, but any help would be good.
Thanks
Thanks
Do you have a Helms manual? It is very easy. This is all from memory:
1. pry off the trainagle plastic cover inside the door covering the mmirror bolts
2. Loosen bolts and disconnect the wire harness for the power mirrors
3. To get to all the bolts easily you may need to pull off the door cover just a bit
4. remove the nuts holding on the mirror (make sure you are holding it)
5. Install new mirror in the same holes. Do NOT over-tighten the bolts/nuts or they will break.
6. re-install the plastic triangle cover
7. put the dooor cover back on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux »</TD></TR><TR><TD CLASS="quote">
1. pry off the trainagle plastic cover inside the door covering the mmirror bolts</TD></TR></TABLE>
this was the main thing i was worried about, any tips or specific ways you did it?
thanks for the help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">Carefully with a small flat head screwdriver should do the trick.</TD></TR></TABLE>
if you want to screw up the paint, sure.
i'd suggest prying it off with hand. thats very easy to do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 255.255.255.255 »</TD></TR><TR><TD CLASS="quote">if you want to screw up the paint, sure.
i'd suggest prying it off with hand. thats very easy to do.</TD></TR></TABLE>
should i take the door panel off or is it easy to do with taking them off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Powered by R} »</TD></TR><TR><TD CLASS="quote">should i take the door panel off or is it easy to do with taking them off?</TD></TR></TABLE>
yes you need to take the door panel off 1st.
Screw up the paint behind the plastic cover.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWEETDUDE »</TD></TR><TR><TD CLASS="quote">Get some pictures, I want to see!</TD></TR></TABLE>
Pictures of what?
Pictures of what?
Careful with it... the metal clip is on a plastic stand-off, if you go too crazy with it, it could break off, you probably should loosen the door liner first, just in case... In any case, if you shift it up to get the plastic clips out of the door holes, then pull straight, I don't think you will have a problem.
Ask me how I know...
epoxying the piece back on does not help either...
and the replacement is a $22.49 item...
Thankfully, even without the metal clip, it stays on reasonably well, provided the door liner is tight
</TD></TR></TABLE>Careful with it... the metal clip is on a plastic stand-off, if you go too crazy with it, it could break off, you probably should loosen the door liner first, just in case... In any case, if you shift it up to get the plastic clips out of the door holes, then pull straight, I don't think you will have a problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2fanboy »</TD></TR><TR><TD CLASS="quote">Careful with it... the metal clip is on a plastic stand-off, if you go too crazy with it, it could break off, you probably should loosen the door liner first, just in case... In any case, if you shift it up to get the plastic clips out of the door holes, then pull straight, I don't think you will have a problem.
pictures would be great if possible!!
</TD></TR></TABLE>pictures would be great if possible!!
Easier to just get a helms.
Declectic
11
Aug 6, 2008 09:39 PM
