brake booster
Well, when my Master was going bad it was dumping fluid into the booster, so it was eating fluid while at the same time making my brakes mooshy. Not sure what happens when the booster goes completely. Brakes get really hard?
i just replaced my master cylinder yesterday and i suspect that my booster is now toast because i got a lot of brake fluid in it. aside from my brake peddle not fading anymore, i still dont have much of a pedal. a sure way to tell if your booster is good is to push the brake while your car is off, and then turn it on with pressure still on the peddle. you should feel the peddle sink a little. if it doesnt sink or just stays the same, your booster is bad. i will be replacing my booster some time this week i think.. i might do a write up of it.. but it shouldnt be too hard to do anyway.
Modified by sanimalp at 11:34 AM 6/26/2005
From the DA helms manual....
Function test:
with car off press pedal hard for 15 sec. If the pedal sinks the mc, brake line, or wheel cylinder is bad.
hold the brake pedal and start the car, the pedal should drop slightly. If it doesn't drop the booster or check valve is faulty.
Leak test:
with the car running press and hold the pedal, turn the car off, if the pedal pressure stays constant for 30 seconds the booster is good. If pedal rises, the booster is bad.
with car off press the pedal normally several times, pressure should rise. If it doesn't look at the check valve.
check valve test:
disconnect the hose from the booster, vacuum should be available.
Function test:
Leak test:
check valve test:
is there a way to change the booster without having to bleed the brakes? cause ive bled them about 4 times for various reasons and i am sick of it. or will i have to do it one more time..
yeah...I just replaced my master and booster and my wheel cylinders...you need to bleed it quit a bit, well that was the experience with me at least. And another thing, just might want to check out the master and wheel cylinders if the booster is bad because in my case it's a domino effect, if one goes bad the others tend to go bad with it. I'm not a brake expert though so just my 2 cents
Yeah, people use integra (non-abs) MC's and boosters that flow a lot more fluid and are more compatible with the bigger teggy calipers and rear disc brakes. Generally they're about the same price so you're better off getting the teg setup so if you do rear disc in the future you already have one of the main parts. All you'd then need is the proportioning valve and all the other brake parts.
stevescivic
13
Apr 14, 2014 02:23 PM
Built B18ABorC
Oct 24, 2004 08:23 PM
