prepping for d15b swap
Old Jun 25, 2005 | 01:45 PM
eg686's Avatar
Default prepping for d15b swap
I pretty much decided that I want a d15b swap. I just need to prepare for it.
I know its a straight swap but I dont think I have the knowledge or the tools get this done. I don't know people who can do it either..so i think I may bring it to a shop.
So far I know its almost a 'bolt on' swap. I just have to wire it for VTEC. So do I need a ex/si vtec harness?
Before dropping it in, I plan on changing the clutch, water pump, spark plugs, and timing belt. Is there anything else worth changing? I don't plan on racing at all...just fast enough to switch lanes on the freeway.
Is it worth it to change the flywheel while I'm at it?
EDIT: Can anyone comfirm that I can use the VX water pump since they are interchangable? I dunno about the distributor or spark plugs. Anyone reccommend any type of clutch? no race please.
Old Jun 25, 2005 | 04:40 PM
eg686's Avatar
Default Re: prepping for d15b swap (dchan86)
ttt
Old Jun 25, 2005 | 05:24 PM
The_Todd's Avatar
Farts in the shower
Searching isn't that hard. I searched under d15b and found TONS of results.
Wiring for vtec: https://honda-tech.com/zerothread?id=724252
Pretty good read for d15b into an eg: https://honda-tech.com/zero...age=1
Another helpful read: https://honda-tech.com/zerothread?id=1183479
t-belt, water pump service on a d16 (should be very similar): https://honda-tech.com/zerothread?id=649277
Another helpful d15b swap (not that indepth): https://honda-tech.com/zerothread?id=1136016
A good swap guide: https://honda-tech.com/zerothread?id=780593
Pics of the swap: https://honda-tech.com/zerothread?id=867473
Come on man...you gotta be able to help yourself too .
Old Jun 25, 2005 | 05:34 PM
FF-sean's Avatar
Old Jun 26, 2005 | 12:32 AM
eg686's Avatar
Default Re: prepping for d15b swap (FF-sean)
thanks
trickster kid
Jul 9, 2009 11:49 PM
lando griffin
May 1, 2006 12:07 PM
Thrillhouse
May 16, 2005 06:07 AM
Phire
Mar 8, 2005 10:32 AM
alleyezonme
Apr 8, 2004 08:26 PM
