Ls turbo teg makes 373whp on pump gas
Old Jun 25, 2005 | 01:23 PM
Teglove2's Avatar
Default Ls turbo teg makes 373whp on pump gas
Finally got my car to the dyno. I've had nothing but bad luck with this car but it's finally tuned! I had a dyno appointment last week but my tuner stood me up and I made a new appointment at Tim Switzer's shop. All I have to say is Tim Switzer is the ****** man! He made sure everything on my car was perfect before leaving. He installed a boost controller, dyno tuned, street tuned for driveability, and did some welding for me. Absolutely outstanding work! For those of you who have seen my previous thread I blew up the first built motor in 550 miles due to not knowing how to set up the ignition timing in the aem and melted the pistons. Got the new motor back together in 3 weeks and got it to the dyno. Well........all I have to say is thanks to all the people that helped me, you know who you are!!!!
Also, made one pass at the track, I know I suck. I really need seat time. Obviously I would have made more passes if my ****** $500 gator stage 2 axles wouldn't have broken.
Pump gas 18psi
Timeslip, I suck, but look at the trap.
Broken gator axle, I need another one Stan!
Tim Switzer tuning my car!
Here's a vid of the dyno pull. Go down to the bottom of the page, right click, save as. Enjoy!
http://www.switzerperformancei...o.htm
Old Jun 25, 2005 | 01:34 PM
bk11383's Avatar
Default Re: Ls turbo teg makes 373whp on pump gas (Teglove2)
awesome man!!!! i have the same car and just abotu the same setup. no dyno tune yet on mine, and i don't think i'll be able to hit your numbers. im shootin for 250 or so. anywho, awesome. now go tear up some american muscle!
Old Jun 25, 2005 | 01:47 PM
redlseg's Avatar
whats your set up?
Old Jun 25, 2005 | 02:00 PM
Teglove2's Avatar
Golden eagle sleeved 84.5mm pistons
Wiseco 8.8:1 pistons
eagle h beams
mild pnp head with obx stage 1 cams
aem sprokets
obx type r replica im
crower dual valvesprings
sfp race manifold
t3/t04e .63 ar/60 trim
3" downpipe 3" exhaust no mufflers
aem tuned with aem wideband
aem 3.5bar map sensor
greddy type s bov
2.5" charge piping
ngk br7e's gapped to .22
aem pulleys
spearco 28.5x8x3 ic
I'm really stoked the power that the car made. I was completely heatsoaked. We drove the car there 1 hour, idled it 20 mins and never shut it off. He said if it was cooler and leaned it out a bit and added a little bit of timing it could have made 400whp easily. It's running about 11.3-11.5 afr and 12 degrees of timing at 18psi, very conservative
Old Jun 25, 2005 | 02:15 PM
projectTeG's Avatar
whats you redine on that motor?
Old Jun 25, 2005 | 02:32 PM
rocket256's Avatar
Default Re: (projectTeG)
Nice but why the low cr? I think if you had of went about 9:3-9:5cr you could have 400 easy!
But all and all good Numbers
Old Jun 25, 2005 | 02:45 PM
s2kdre's Avatar
Default Re: (rocket256)
sick i cant wait to get my new motor on the dyno.
Old Jun 25, 2005 | 02:48 PM
Dunc's Avatar
BCICAN
Nice trap speed haha, can you say wheel spin??
Old Jun 25, 2005 | 03:05 PM
dc2legend's Avatar
Default Re: (Dunc)
Nice, glad to see it all together for you.
Old Jun 25, 2005 | 04:11 PM
qksl2's Avatar
Default Re: (Teglove2)
With that little timing, what were your EGT's at?
Ian
Old Jun 25, 2005 | 04:23 PM
CXHATCHver2.2's Avatar
Default Re: (dc2legend)
yeah, gotta get those 60fts down, a 2.0 and you could be in the 12's pretty easily and pretty deep with that kinda hp. What do you launch at and what tires are you running, cause my buddy has a mild ls-t build pushing 9.5lbs and he ran a 13.7 @ norwalk, he was running 14in. steelies on bfg's @20psi and launched at around 5500
His run:
60ft. = 2.053
1/8et. = 8.837
1/8mph = 83.73
1/4et. = 13.722
1/4mph = 99.99
Old Jun 25, 2005 | 05:05 PM
Ri5e's Avatar
Default Re: (CXHATCHver2.2)
Wow, awesome torque!
Old Jun 25, 2005 | 05:32 PM
leed's Avatar
Default Re: (TurboSmart)
Deff. some freight train TQ there hahah. Bet 4th on the freeway feels good.
Old Jun 25, 2005 | 06:02 PM
Teglove2's Avatar
Yeah It pulls hard as **** on the freeway. I've been driving it tonight and it ripped 3rd gear. I love the powerband it's sick. My redline on the car is 7800. I was runnin 2 piece weld wheels with 22x15x8 slicks at 12psi. I'm pretty sure I caught dry pavement when I did the burnout and that's how I broke the axle. It's definitely faster than I thought it would be and much more than I need for the street. Thanks for the compliments, def makes it all worth it!
Old Jun 25, 2005 | 06:17 PM
Turbocivic94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote"> Obviously I would have made more passes if my ****** $500 gator stage 2 axles wouldn't have broken.
Nice #'s
I'm getting scared of running my gator axles after seeing all these broken gator axles
Old Jun 26, 2005 | 12:16 PM
Teglove2's Avatar
Just got back from the track today. Did a best of 12.8. Best trap speed of 118mph! Will post vids/time slips very soon.
Old Jun 26, 2005 | 12:52 PM
fqnjdmboy's Avatar
hey ryan..maybe on wednesday we will go to the track together and Ill make a pass in it with my slicks...see what I can do with her...haha
Old Jun 26, 2005 | 12:59 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">Broken gator axle, I need another one Stan!
God I hate having to see this
Good luck with the car.
Old Jun 26, 2005 | 01:40 PM
.adam.'s Avatar
Default Re: Ls turbo teg makes 373whp on pump gas (0x64)
heh thats funny. i live about 4 or 5 blocks from switzer performance.
Old Jun 26, 2005 | 01:56 PM
fqnjdmboy's Avatar
really where do you live..I live in Lagrange...and am always up at tyms shop....
Old Jun 26, 2005 | 06:22 PM
Teglove2's Avatar
Default Re: (fqnjdmboy)
We fixed the broken gator axle and got a stocker back in and made my way back to the track. I can't hook up with the 22 inch slicks but the car mph's like crazy. Not only that it was 93degrees and 60%humidity. All in all we had fun! Well..here's the slip and a couple of vids.........enjoy!
O yeah, I'm car number 56
Here's a small vid
http://www.we-todd-did-racing....DE%3D
Old Jun 27, 2005 | 10:39 AM
PM-Performance's Avatar
obviously you did hook up with those slicks if you broke a stage 3 axle dude.
Nice that you got into the 12's though.
I know it feels good.
Im still curious about the timing. If the timing was really 12degrees under boost you have a ton more power to make.
Old Jun 27, 2005 | 10:44 AM
Bserieskllr's Avatar
you have a 1.64 60', you were def. hooking.
Old Jun 27, 2005 | 10:56 AM
you sure the times are correct?
1.6 60ft for 22inch slicks on 370whp. And only cracking a 12.80 with that? You say your driving suck , but if you hit a 1.6 60' and then shitted up all your shifts you are backwards as hell. lol
Old Jun 27, 2005 | 10:17 PM
Teglove2's Avatar
exactly...the run I went 12.8 I couldn't get the car into 2nd gear........it revs so fast in 1st gear I can't get it into 2nd fast enough and it bogs 2nd gear down to like 4k and l lost MAD time........just need some more seat time.
BuiltnotboughT2
May 27, 2018 08:40 AM
guy_from_nerk
Aug 17, 2012 12:41 PM
NLR808
Oct 7, 2010 11:23 AM
97hb
Feb 28, 2009 05:22 PM
revhardsi
Dec 19, 2002 04:42 PM
