compression numbers need help
After finally getting a compression gauge i can further tech my motor to see whats the problem but i got some compression numbers and i dont know what to think of them.
Cylinder 1- 232 psi
cylinder 2- 228 psi
cylinder 3- 234 psi
cylinder 4- 224 psi
average psi in motor 230.
Is it normal to have a high and low with a diffrence of 10 psi's. thanks in advance for you help
Cylinder 1- 232 psi
cylinder 2- 228 psi
cylinder 3- 234 psi
cylinder 4- 224 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tobe2be »</TD></TR><TR><TD CLASS="quote">no and no. i havent been able to start my car in about a week. i did disconnect the dizzy so that i wont blow the ignitor.</TD></TR></TABLE>
Next time do it with the motor warm, and pull the ECU fuse out for a more accurate reading.
HatchBox
Aug 4, 2003 03:41 PM
