Strange Header Sound After Install
Old Jun 24, 2005 | 09:36 PM
Tarh33l10's Avatar
Default Strange Header Sound After Install
I just installed a Alphawerks header. I got it for wholesale so I figured I'd give it a shot. Looks like a DC basically. Anyways, after installing it, it sounds really loud when i barely give it gas, and kinda sounds like its ticking or fluttering, but you can tell it is air. I don't think it is supposed to sound that way, it is really obnoxious sounding, and really makes me wanna take it back off if you know what i mean. It didn't come with a gasket for the collector to the cat, so i was thinking maybe that is where my problem is. Also, the top gasket seemed a little bent, but I would think it would compress once tightened. We went back through and tightened all the bolts real real right, and it hasn't changed. Please let me know what is going on. I also couldn't tell any power gains, maybe even seemed like it lost a little bit.
Old Jun 24, 2005 | 10:37 PM
shreker's Avatar
Default Re: Strange Header Sound After Install (Tarh33l10)
you need the header gasket!but if you have it then,you might of put it no crooked.check to see if any air is leaking out!
Old Jun 25, 2005 | 03:33 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Strange Header Sound After Install (shreker)
You got what you paid for.
Old Jun 25, 2005 | 05:56 AM
Tarh33l10's Avatar
Default Re: Strange Header Sound After Install (Sticky Tires)
Look I'm just looking for advice, the headers are dyno proven. So if all you're gonna say is how I shoulda got prospeed or some other high dollar header, then don't reply. How much louder does the car typically sound with a set of headers.
Old Jun 25, 2005 | 06:13 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarh33l10 &raquo;</TD></TR><TR><TD CLASS="quote">Look I'm just looking for advice, the headers are dyno proven. So if all you're gonna say is how I shoulda got prospeed or some other high dollar header, then don't reply. How much louder does the car typically sound with a set of headers.</TD></TR></TABLE>
It is going to sound like **** since you installed 2 headers on a 4 banger.
Another thing, it would be nice to tell us what engine you have.
Old Jun 25, 2005 | 08:15 AM
RMF
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">
Another thing, it would be nice to tell us what engine you have. </TD></TR></TABLE>
Hate to tell you this .But he's right.There is 4 header pipes ,Which make it a set of headers.So when you go to buy HEADERS for your four cylinder.Your saying it correctly.
Old Jun 25, 2005 | 08:23 AM
* B A N N E D *
Default Re: Strange Header Sound After Install (RMF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">
Hate to tell you this .But he's right.There is 4 header pipes ,Which make it a set of headers.So when you go to buy HEADERS for your four cylinder.Your saying it correctly.</TD></TR></TABLE>
You are right, but I wasn't referring to that.
Old Jun 26, 2005 | 11:41 AM
Tarh33l10's Avatar
Sounds like sticky tires knows jack **** about headers, or is it header? Haha, go post on some other thread where some other idiot gives a ****. I figured out my problem already, and by the way Alphawerks makes a great header for the H22 A4 at a reasonable price.
Old Jun 26, 2005 | 12:06 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarh33l10 &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like sticky tires knows jack **** about headers, or is it header? Haha, go post on some other thread where some other idiot gives a ****. I figured out my problem already, and by the way Alphawerks makes a great header for the H22 A4 at a reasonable price. </TD></TR></TABLE>
So.. what was the problem?
Old Jun 26, 2005 | 03:46 PM
Tarh33l10's Avatar
Default Re: Strange Header Sound After Install (md23vtec)
We believe the gasket that came with the header had a slight bubble in it, causing it to bust. We made a gasket for it and it worked fine.
Old Jun 26, 2005 | 05:43 PM
Don Jefe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF &raquo;</TD></TR><TR><TD CLASS="quote">Hate to tell you this .But he's right.There is 4 header pipes ,Which make it a set of headers.So when you go to buy HEADERS for your four cylinder.Your saying it correctly.</TD></TR></TABLE>
Bleh, ill play it safe and just call it an exhaust manifold lol
Old Jun 27, 2005 | 02:25 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tarh33l10 &raquo;</TD></TR><TR><TD CLASS="quote">We believe the gasket that came with the header had a slight bubble in it, causing it to bust. We made a gasket for it and it worked fine.</TD></TR></TABLE>
Again, you get what you paid for.
Old Jun 27, 2005 | 11:21 AM
matix's Avatar
Go buy a gasket for the cat. Thats probably your problem. The fluttering your hearing is the exhaust leak were your cat connects to the downpipe. It also could be a broken flexpipe if that header has one. Get under the car and see if it shot black soot up under the car by the cat that will tell u if its been leaking.
Old Jun 27, 2005 | 11:31 AM
optikal_blitz's Avatar
i think they already solved the problem...
runners = header
header = exhaust manifold
headerS = exhaust manifolds
unless you have two banks, any honda b, f, h, d, k, series will have a header.
but then again.. simply semantics.
jered247
Honda Civic (2001 - 2005)
15
May 13, 2006 04:13 AM
hakkoo
Feb 24, 2006 10:42 AM
suken19
May 14, 2005 03:30 AM
aandDavidsaid
24
Jul 30, 2004 12:32 PM
bushfreakz
15
Jul 17, 2003 04:00 PM
