how often to replace?
Old Jun 24, 2005 | 09:12 PM
fanta!'s Avatar
Default how often to replace?
how often do you have to replace the battery? ive had the same battery for 4 years now.
what are some common signs of the battery going out or needing a replacement? can you take it to an autozone or something for them to check and charge it or should i just buy a new one?
Old Jun 24, 2005 | 09:15 PM
crxnj's Avatar
Default Re: how often to replace? (father)
The battery should have the lifespan written on it..And that's when you should technically change it ..But you can get some more out of it usually..But yeah autozone tests it for free as well as the alternator..
Old Jun 24, 2005 | 09:24 PM
EL Vap133's Avatar
Once it takes longer to turn the car on.
Old Jun 24, 2005 | 09:29 PM
dh's Avatar
dh
Default Re: how often to replace? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Once it takes longer to turn the car on. </TD></TR></TABLE>
When it feels you have to hold the key longer on start..
Old Jun 24, 2005 | 09:55 PM
bagpipe goatee's Avatar
well, since i drive a manual that's easy to pushstart, i usually wait until it gives me problems.
Old Jun 24, 2005 | 10:09 PM
mr. carpenter's Avatar
Default Re: (bagpipe goatee)
you probably just doomed that battery. as all have said the car will not start as quick. you might also notice things dim when other components are turned on like the lights or ac.
Old Jun 24, 2005 | 10:13 PM
fanta!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">well, since i drive a manual that's easy to pushstart, i usually wait until it gives me problems.</TD></TR></TABLE>
yeah i do notice that things are dimming. is it a sign of i need a new one or can it just be charged
**also what do i look for when im shopping for a battery? brand,type,volts?
Old Jun 24, 2005 | 10:53 PM
dimming can be caused by bad grounds, weak alternator, weak battery, and of course a couple other things. whatever it is, it usually puts more stress on the battery, though.
first, i'd go for the cheap and clean up the grounds and positive cables, and get your alternator tested, but since your battery is old, it's probably just at it's time.
a couple weeks ago, i replaced one that was 5.5 years old. but i don't have a boomin' system in my car.
Old Jun 24, 2005 | 10:56 PM
oakpwr's Avatar
man anytime ive had the battery for four or more years as soon as it starts to not fire up the car right away i change it. sears diehard makes the best but they are expensive so now i just go to costco and pick up the cheaper ones.
Old Jun 24, 2005 | 11:39 PM
fanta!'s Avatar
Default Re: how often to replace? (oakpwr)
how much cca is good?
Integ808
Oct 16, 2008 02:57 AM
hon da top
Mar 28, 2008 06:57 PM
cvaladez2
26
Mar 10, 2007 09:41 AM
MooreBoost
Aug 31, 2005 08:53 PM
calean
Nov 18, 2004 03:55 PM
