COMPRESSION TEST DONE; HAVE QUESTIONS??
Old Jun 24, 2005 | 07:06 PM
JoseCuervo's Avatar
Default Compression Test Done; Have Questions??
I just completed a compression test on a 99 Honda Civic EX, stock internals, turbocharged since early 2000 with an F-Max turbo kit. The test was done at normal operating temperatures. Here are the results:
Cyl #1: 205
Cyl #2: 200
Cyl #3: 210
Cyl #4: 205
The needle on the gauge moved as follows for every cyl: 1st crank jumped to 90psi and then moved up gradually to the final number. Each cyl was cranked about 7 cycles. I know the numbers are high since the max is supposed to be about 184psi. Let me know what you think. Thanks!
Modified by JoseCuervo at 3:28 AM 6/25/2005
Old Jun 24, 2005 | 08:21 PM
TeamNextGenChris's Avatar
Default Re: COMPRESSION TEST DONE; HAVE QUESTIONS?? (JoseCuervo)
they look good to me.it can take a couple cranks to get an accurate reading.i'd only be concerned if a cylinder never reached an acceptable number after a few cranks.
is there a reson for the test?any problems?
also,you need to read the rules posted at the top of this forum:
2.B. Please do not make thread titles in all caps or with symbols that will attract attention. This steers users away from the other (most likely more important) threads on the page
chris
Old Jun 24, 2005 | 09:09 PM
neutron91's Avatar
Default Re: COMPRESSION TEST DONE; HAVE QUESTIONS?? (TeamNextGenChris)
that looks really good... wish mine were that high
Old Jun 24, 2005 | 11:10 PM
SOHCEK-Turbo's Avatar
Default Re: COMPRESSION TEST DONE; HAVE QUESTIONS?? (neutron91)
Those numbers are good how much are you boosting? To boost that engine since 2k that is good.
Modified by EK-TSOHCV-TechRider at 8:48 AM 6/25/2005
Old Jun 25, 2005 | 02:24 AM
JoseCuervo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">they look good to me.it can take a couple cranks to get an accurate reading.i'd only be concerned if a cylinder never reached an acceptable number after a few cranks.
chris</TD></TR></TABLE>
Thanks for the reply. There's a few reason for the test: the engine has been under boost since early 2000; sometimes, when I get on it hard, she blows a small white puff of smoke; I'm about to change the fuel/engine management to a stand alone one, get a new turbo (the current one has leaky seals), plus a few other things. I also believe that I have the D16Y8 main problem, head lifting. I have small traces of oil in the coolant reservoir. Pretty soon I'll be taking the head off to replace the head gasket and change the head bolts to ARP head studs. Sorry about the all caps title, it was late at night. It won't happen again!
Old Jun 25, 2005 | 02:27 AM
JoseCuervo's Avatar
Default Re: COMPRESSION TEST DONE; HAVE QUESTIONS?? (EK-TSOHCV-TaKRider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-TSOHCV-TaKRider &raquo;</TD></TR><TR><TD CLASS="quote">Those numbers are good how much are you boosting? To boost that engine since 2k that is good.
Modified by EK-TSOHCV-TechRider at 8:48 AM 6/25/2005</TD></TR></TABLE>
Thanks! The boost is set as follows: low boost - 6 psi, high boost - 10 psi. Before the boost controller, it was set at 12-13 psi. The car only has 49K miles.
drave
Nov 21, 2010 01:55 PM
godnf8
Feb 12, 2007 07:33 AM
elpiar
Apr 5, 2005 09:35 PM
quaker
Jan 5, 2005 05:33 AM
AdamITR
Jul 22, 2002 01:32 AM
