Compression Test Numbers ... Help.
Old Jul 21, 2002 | 11:02 AM
AdamITR's Avatar
Default Compression Test Numbers ... Help.
#1 (driver side) - 210
#2 - 230
#3 - 213
#4 (passenger side) - 211
Is this okay ... why is #2 so much higher?
Old Jul 21, 2002 | 11:06 AM
Chubz's Avatar
Default Re: Compression Test Numbers ... Help. (AdamITR)
did u do this after the car was at normal opertaing temp. How long has it been since your last valve adjustment. Thse could contribute to in accurate compression test number. Try the test at least twice. Also a compression test will only tell you if there might be anything wrong. A leakdown test will lead you to the actual problem.
[Modified by SuperTech, 8:08 PM 7/21/2002]
Old Jul 21, 2002 | 12:49 PM
Tommy_Gunns's Avatar
That's funny, my #2 cylinder is the lowest.
Old Jul 21, 2002 | 01:04 PM
BlueR's Avatar
Default Re: Compression Test Numbers ... Help. (Tommy_Gunns)
i did a compression test 2 months ago and got
210, 211, 210, 220
and i also wondered why my last number was too high, but everyone told me they were fine so... just wanted to give you a point of reference
Old Jul 21, 2002 | 01:07 PM
Default Re: Compression Test Numbers ... Help. (BlueR)
I got (in no particular order):
225, 225, 219, 211
I forgot which number was for which cylinder (I got it written down somewhere but I'm too lazy to look).
[Modified by Tommy_Gunns, 4:08 PM 7/21/2002]
Old Jul 21, 2002 | 02:04 PM
Willard's Avatar
my numbers...
https://honda-tech.com/zerothread?id=176578
looks like your #2 is near the norm.
Will
Old Jul 21, 2002 | 08:39 PM
AdamITR's Avatar
Default Re: Compression Test Numbers ... Help. (Willard)
No ... the first time, the car was cold. So, I let the car warm up to operating temp and re-tested the compression. This time, all the cylinders tested between 220 & 225. All is well
Old Jul 22, 2002 | 01:28 AM
Cyber ITR's Avatar
is that for B18C5 engine ??
i got JDM B18C bout the same , well not anymore , since its being boosted to hell , compression ****** up now
190 190 190 190
ghey
Old Jul 22, 2002 | 01:32 AM
Drag R's Avatar
i did mine a couple just before we pulled the motor and i got
1-240
2-240
3-250
4-240
Bone stock
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
92vxjdm
Aug 15, 2008 05:05 AM
John.
Jun 12, 2006 08:45 AM
quaker
Jan 5, 2005 05:33 AM
