Fuel Pump Problems
Old Jun 24, 2005 | 06:51 PM
Kaneo's Avatar
Default Fuel Pump Problems
Its a jdm b16, sometimes i can here the pump prime then the car starts then dies and i wait a few minutes and its starts fine. Other time i cant hear the pump and it doesnt start. Could it be the ignition module or is it just the fuel pump? Or anytime else? Thanks in advance.
Old Jun 24, 2005 | 07:06 PM
Proglow3's Avatar
Default Re: Fuel Pump Problems (Kaneo)
I'm not sure about b16's, but when I had that problem in my 93' civic it was my main fuel relay. If you use one of those...maybe it's intermittent.
Old Jun 24, 2005 | 08:04 PM
TeamNextGenChris's Avatar
i'd say the main relay.from my experience,a bad fuel pump stops working and doesn't work again.
the main relay going bad would work intermittently-just like you've described.
wouldn't be a bad time to replace the fuel filter too.
Chris
Old Jun 24, 2005 | 08:10 PM
c_buz's Avatar
Default Re: Fuel Pump Problems (TeamNextGenChris)
where is the main relay?? is it underneath the dash in the drivers kickpanel??
Old Jun 24, 2005 | 08:31 PM
Default Re: Fuel Pump Problems (c_buz)
yes,it is behind the bottom part of the dash on the driver side.
if you do a search for "main relay" you'll find threads with pictures of it so you'll know what you're looking for.
chris
Old Jun 24, 2005 | 08:43 PM
Kaneo's Avatar
Thanks for all the replies guys. Much appreciated
slowEGles
May 13, 2013 06:16 PM
400whp
Apr 28, 2011 02:20 PM
slowassBubble
Mar 17, 2011 06:12 PM
916MINI
11
Aug 11, 2008 09:51 AM
go4wheeling
Sep 18, 2006 03:43 AM
