Any you turbo gurus know KKK turbos?
Old Feb 12, 2002 | 08:12 PM
dbman96's Avatar
New User
Default Any you turbo gurus know KKK turbos?
Hey guys just got a pretty simple question - do you know if the KKK turbo line is similar to the Garrett models in the center housing being interchangeable? Like the way you can bolt a T4 backplate, wheel and housing onto a T3 turbine and center section? I'm wondering if it's possible to do a "hybrid K03/K04" type setup (shopping for audis... sorry guys )
Old Feb 12, 2002 | 08:13 PM
b18bturbo's Avatar
Default Re: Any you turbo gurus know KKK turbos? (dbman96)
for the 1.8t audi/vw motor go with a k04 upgrade or t3/t4 upgrade. check out 8vturbo.com
Old Feb 12, 2002 | 11:30 PM
dbman96's Avatar
New User
Default Re: Any you turbo gurus know KKK turbos? (b18bturbo)
Thanks... I know there are easy turbo swaps available - there's actually a good reason I'm trying to figure out if the center sections are swappable like the T3 and T4. We're doing some work on the K03 center section at work (basically a full custom bb housing with some... extra equipment) and it would be reallly handy if we could bolt K04 parts onto that same center section; would really make for a versatile platform if we have that whole range of compressors to choose from.
Within a few weeks I will likely have a pretty solid assortment of K03 and K04 parts all over my office but I was hoping to get a head start on that little bit of info if anyone could help out.
Old Feb 13, 2002 | 03:20 AM
DragII's Avatar
yes this is possible...I have seen it done a few times. check out http://www.vwvortex.com
Old Feb 13, 2002 | 01:05 PM
dbman96's Avatar
New User
Default Re: Any you turbo gurus know KKK turbos? (DragII)
Ah I guess it turns out the K03 and K04 aren't as different as a T3 and a T4... more like the difference between a T04B and a T04E... mostly a difference in internal parts, same basic size. I've got a K03 sittin here and the thing is TINY after working with a T3/4 hybrid. Both the K03 and K04 are significantly smaller than a straight T3.
Old Feb 13, 2002 | 01:59 PM
shamoo's Avatar
Will you make something up for me please?
My friend has a K03 which he had in his Audi before he blew it. Looks small as dbman said.
Anywho, you should get the PES kit...it has a T28 turbo (no intercooler). Check it out at http://www.pes-tuning.com
Old Feb 13, 2002 | 02:12 PM
dbman96's Avatar
New User
Default Re: Any you turbo gurus know KKK turbos? (shamoo)
The 1.8T has a stock intercooler though, doesn't it?
Old Feb 13, 2002 | 07:37 PM
shamoo's Avatar
Yeah, a small one on the driver's side of the car. I'm not sure if the PES T28 kit gets rid of it though.
Old Feb 13, 2002 | 08:20 PM
stevel's Avatar
The K04 turbo has the same size housing as the K03 I believe. The K04 just has a bigger turbine inside. Don't hold me to it but I'm quite positive when I saw an aritcle in VW tuner and they did a K04 upgrade on a passat and they put them side by side and they looked the same. So, if you're doing work to the center section like opening it up a little more you might be able to fit K04 parts into it. Garrett makes a ball bearing turbo part of there ballistic series made to replace the K03. Check out the whole package at http://www.goapr.com. They've got really good stuff for audi/vw turbo engines. Hope this helps.
S
Rage Cayman
Oct 7, 2005 07:54 AM
Dancing is Forbidden
May 23, 2003 07:32 PM
EGJDM
Apr 19, 2003 03:10 PM
