Test Pipe on, so is cel.
Old Feb 12, 2002 | 08:08 PM
3rdGteg's Avatar
Default Test Pipe on, so is cel.
Thowing code like 63 or 64 as far as I can remember(procrastinating to fix this one). What's the best way to get rid of the CEL if I want to keep runnin the testpipe? Also, does this code put my car in safe mode or anything- my car seems to run good sometimes and weak other times.
Thanks.
Old Feb 13, 2002 | 10:29 AM
b18b98's Avatar
Default Re: Test Pipe on, so is cel. (3rdGteg)
get a 96 ECU for your car.
Old Feb 15, 2002 | 12:08 PM
3rdGteg's Avatar
Default Re: Test Pipe on, so is cel. (b18b98)
It is a 96 ecu .... in a 96 car....
Old Feb 15, 2002 | 12:17 PM
Greyout's Avatar
then its OBD II. get an O2 simulator for your second o2 sensor
Old Feb 15, 2002 | 08:11 PM
Racer's Avatar
What size of testpipe are you using? Stock header? Does the testpipe has 2 O2 sensor mounts?
Old Feb 15, 2002 | 09:25 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Test Pipe on, so is cel. (Racer)
Skunk2 OBD2->OBD1 harness, get a 94-95 OBD1 computer....
or... O2 sensor simulator.... Might as well go for the computer conversion if you are going to be doing any serious upgrades in the future.
Old Feb 16, 2002 | 01:33 PM
JeffS's Avatar
Does your test-pipe have 2 O2 bungs? It should...
If it did, you could get some catalyst, stick it in the second bung, underneath the 2nd O2 sensor and the CEL goes away. Many places like http://www.testpipe.com sell this setup. It would be cheaper to buy a new pipe from them than buy an O2 simulator.
Old Feb 16, 2002 | 09:02 PM
3rdGteg's Avatar
Default Re: Test Pipe on, so is cel. (JeffS)
JeffS: I did buy my testpipe from testpipe.com, but mines didn't come with any place to put the o2 sensor so what can I do?
Old Feb 17, 2002 | 06:03 PM
96Integ's Avatar
I thought that the ones they sell at testpipe.com came with the bungs. It says on thier site "96-00 INTEGRA 2.50" COMES WITH 2 WELDED O2 SENSOR BOSSES FOR THE SENSORS " hmmmmm. I was going to buy one from them, I assumed you could just install it then not have any hassles. Does anyone else have advice about this??
aberabee
Dec 2, 2009 05:41 AM
beastman@
Jul 10, 2008 08:53 AM
b16wannaride
Sep 16, 2002 12:02 PM
comptechgsr2000
Apr 25, 2002 09:26 PM
