Compression test results (Turbo JDM GSR)
Old Jun 24, 2005 | 07:47 AM
ChronicGreenDC2's Avatar
Default Compression test results (Turbo JDM GSR)
today I did a compression test to see how healthy the motor was. I followed the directions from the C-speed site and I came up w/ 220psi across the board (give or take a hair or two) nothing within 5psi on each other. I couldn't believe it, so I tested again, same results.
C-speed sayz 5 cranks, but I noticed the more I cranked it the higher the gauge went. The numbers I used were off the 5 crank spot.
Whats the deal?
Old Jun 24, 2005 | 07:51 AM
mmuller's Avatar
Mad Scientist
Default Re: Compression test results (ChronicGreenDC2)
yeah compression will keep going up up to certain point, then it will stop.
Just use a base cranking for all and your good, i usually do 7-8 cranks in wich the compression press. should be pretty much at its max
Old Jun 24, 2005 | 09:08 AM
snowseeker's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChronicGreenDC2 &raquo;</TD></TR><TR><TD CLASS="quote">today I did a compression test to see how healthy the motor was. I followed the directions from the C-speed site and I came up w/ 220psi across the board (give or take a hair or two) nothing within 5psi on each other. I couldn't believe it, so I tested again, same results.
Whats the deal?
Whats the deal with what? Looks high for a turbo motor.
Old Jun 24, 2005 | 09:30 AM
Default Re: Compression test results (snowseeker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">
Whats the deal with what? Looks high for a turbo motor.</TD></TR></TABLE>
I was just making sure everything was cool, 2 cranks put it at 180psi, 5 cranks brought it up to 220psi, 8 cranks looks like to would be close to 250psi.
But I guess that really doesn't matter, as long as w/ 2 cranks they were all 180psi and so on and so on.
Tell you the truth, I was just very surprised to see such good results.
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
xd69
Mar 7, 2006 12:10 PM
snowblind7x
Apr 13, 2005 08:12 PM
Mr.Integra
Apr 22, 2004 07:55 PM
geminis2k
Oct 6, 2003 03:47 PM
