vacuum at idle?!?
Old Jun 24, 2005 | 06:18 AM
mrx's Avatar
mrx
Default vacuum at idle?!?
Hallo,
today i noticed that my car only hat aprox. 400mbar absolute pressure at idle and at mid revs (4000-5000rpm) during fuel cut off i have also only 350mbar...
normaly i thought my car sucks more vacuum at idle and even when you go close the throttle at high revs.
is this normal (maybe weather conditioned) or do i have something like a vacuum leak or something? What else is possible?
Thanks
Malte.
Old Jun 24, 2005 | 08:29 AM
Cee_mon's Avatar
Default Re: vacuum at idle?!? (mrx)
i idle at -500mm/HG
Modified by Cee_mon at 6:33 PM 6/24/2005
Old Jun 24, 2005 | 09:48 AM
dustin's Avatar
Default Re: vacuum at idle?!? (Cee_mon)
On stock GSR at idle (fully warm) I see -600mm/HG which is about -800mbar. you guys really see that little vacuum?
You should see at least -20in/HG, which is ~508mm/HG or ~677mbar.
What elevation are you at?
Old Jun 24, 2005 | 10:04 AM
m R g S r's Avatar
Default Re: vacuum at idle?!? (dustin)
ahh stupid defi BF gauges
I see .6-.8 (on my defi BF)
Old Jun 24, 2005 | 10:10 AM
dustin's Avatar
Default Re: vacuum at idle?!? (m R g S r)
.6 to .8 what? hehe kg/cm^2? if so, that seems alright.
Old Jun 24, 2005 | 10:12 AM
m R g S r's Avatar
here..just took a pic at idle:
Old Jun 24, 2005 | 10:14 AM
dustin's Avatar
ahh, about -75kPa... that is about right.
canon
Old Jun 24, 2005 | 10:16 AM
m R g S r's Avatar
blahh...i hate my camera..im gettin the digital rebel XT as a graduation gift next week! can't waiit!
Old Jun 24, 2005 | 10:17 AM
dustin's Avatar
you don't like it? I've always loved my canon cameras...
Old Jun 24, 2005 | 12:13 PM
mrx's Avatar
mrx
i also thought that the vacuum was higher some month ago...
my elevation is something about 300m above n.n. so nothing special...
as i drive home now, i have 500mbar abs. at idle, but car was not fully warmed up... later it went to 400mbar...
very curious ... is there a chance of a vacuum leak somewhere? i also notices power loss and my turbo smokes like hell (i think the bearing is broken) but when i take everything together, maybe its something simple like a vacuum leak or something... what do you think?
i think i will remove the bumper and recheck very connection in the charge system... maybe a clamp is broken or loosen...
Hope to get some more ideas...
Thanks
Malte.
Old Jun 24, 2005 | 01:00 PM
dustin's Avatar
Could be, but the vacuum leak should cause the car to idle and drive poorly...
Leaks in the charge system will not affect your vacuum at idle... it would have to be a leak *after* the throttle plate...
Old Jun 24, 2005 | 07:31 PM
gyrluknouwantme's Avatar
i'm only geting 10-15 in/hg, but i assume having absolutely no atmosphere at my shitty elevation of 5300' is a contribuiting factor....
Old Jun 24, 2005 | 11:34 PM
mrx's Avatar
mrx
Default Re: (gyrluknouwantme)
hm, the picture of MrGSR look like mine as it was before ;-)
very strange... today i checked very vacuum hose and connection with carb. cleaner without any effect... i also checked the injector seals because i use dsm 450ccms and had to bore mine out with a dremel... so i thought i have a leak there but there is no.
Intake Manifold gasket and throttle body gasket seems also ok.
can it maybe something engine internal???
the engine idles good with the low vacuum, i have a stable idle rpm of ~1000rpm (i put it a littlebit up for better throttle response some time ago) no staling, good response at low rpms the only thing is that it is impossible to get lower vacuums then 400mbar (absolute) in ANY driving condition!
is it possible that this is my broken turbo in the exhaust? maybe its too restrictive now? some experiences?
Thanks
Malte.
Old Jun 25, 2005 | 08:00 AM
dustin's Avatar
Default Re: (mrx)
Maybe your gauge is broken
Old Jun 25, 2005 | 08:01 AM
mrx's Avatar
mrx
Default Re: (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">Maybe your gauge is broken </TD></TR></TABLE>
only at vacuum?! i don't think so... maximum boost readings are accurate and by the way datalogging show nearly the same like the boost gauge
GSTDA9
Feb 7, 2008 03:59 PM
bOOsTiNSoHcVtEc
Apr 23, 2007 10:07 AM
UNKNOWN_MEMBER
Aug 11, 2005 08:55 PM
Cuong-nutz
Nov 25, 2004 10:34 AM
Civic Racer X 7
Jul 23, 2003 07:19 AM
