Switch for Turboxs Dual BC. What kind to use...
Old Jun 23, 2005 | 06:48 PM
Battle Mike's Avatar
Default Switch for Turboxs Dual BC. What kind to use...
I got a dual boost controller for cheap...turboxs one. It didn't come with the switch. no big deal as I hate the switch that comes with it. I wanted something a little smaller than what it usually comes with.
so, my question...is there a certain type I should look for? Or are all switches the same...i.e. on/off. I assume that's what the turboxs does? When it turns "off" it's basically switching it back to the other setting for the controller.
Any help would be great. I want to make sure I know what switch to look for...not too familiar with this type of stuff
Old Jun 23, 2005 | 06:49 PM
Default Re: Switch for Turboxs Dual BC. What kind to use... (02SilverSiHB)
also...can I just get a push type of button versus the toggle type it usually comes with
Old Jun 23, 2005 | 06:52 PM
like this kind of push button...just an idea...I'm thinking maybe this type won't work?
http://cgi.ebay.com/ebaymotors...&rd=1
I actually have a couple of switch buttons sitting around...oem honda ones...but I'm thinking that type won't work?
Old Jun 23, 2005 | 07:29 PM
tommyten's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02SilverSiHB &raquo;</TD></TR><TR><TD CLASS="quote">like this kind of push button...just an idea...I'm thinking maybe this type won't work?
I actually have a couple of switch buttons sitting around...oem honda ones...but I'm thinking that type won't work?</TD></TR></TABLE>
no they wont work unless you find one that is stays pressed in after you push it. Its needs to hold current or ground in order for the solenoid to activate. So if you use a push starter button or "momentary" button then your high boost solenoid will only activate for however long you hold the button down.
Old Jun 23, 2005 | 07:40 PM
Default Re: Switch for Turboxs Dual BC. What kind to use... (Tommy tit)
ah, okay. I got it now. Thanks man
Old Jun 24, 2005 | 04:26 PM
well, I ended up getting this one at autozone..I guess it should work
has a place for power, ground, and "load"...I guess that's for the signal sent to the controller
It matches the interior...it's black and suttle looking. Has some led on it that lights up amber when I switch it on.
fryman
Honda Motorcycles
Jan 23, 2012 03:12 PM
Bludger
Sep 26, 2010 07:57 AM
EG-SIXV-TEC
28
Feb 20, 2009 07:39 PM
twkdCD595
Feb 19, 2003 10:13 AM
