SC34 which Turbine Trim for B16?
Hallo,
i wan't to buy a SC34 for my B16 and want to know which Turbine Trim fits better for a B16
69 Trim or 76 Trim?!
Turbine AR is a .63 and the Compressor Trim is 57.
am i right that the 76 Turbine Trim would spool a bit later but have more top end performance? or is it too big for a B16...
Thanks
Malte.
Thanks
Malte.
Re: SC34 which Turbine Trim for B16? (mrx)
get a 69trim...not too big..not too small...more protential for later if you needed to add a few psi.
Also...if anyone is interested...I have a used setup for sale.
https://honda-tech.com/zerothread?id=1264157
Modified by cinq at 10:00 AM 6/10/2005
I'm running the 69 trim(stage 2) exhaust wheel on my SC34 on b16. Dyno numbers in sig. that's with bad exhaust leaks. with exhaust leaks I'm not seeing 11psi till a good 5500rpm. without exhaust leaks it's a few hundred rpm lower.
