COMPRESSION TEST! results....comments welcomed
Old Jun 23, 2005 | 11:23 AM
Azcheron's Avatar
Default COMPRESSION TEST! results....comments welcomed
Ok, well like i mentioned in another thread...we are having a hell of a time figuring out why we cant get the Supercharged setup on my car to run smoothly for DD...
so we started with a compression test to make sure all was well and dandy
the test came back like so:
240 240 230 240
is there any need to do a leakdown test if i got these numbers?
Old Jun 23, 2005 | 11:29 AM
Bbasso's Avatar
Default Re: COMPRESSION TEST! results....comments welcomed (Azcheron)
What's to comment on the #s ? they are good.
As for leak-down testing, It's different then Compression and should be tested.
Old Jun 23, 2005 | 11:32 AM
Dave_B's Avatar
Not necessarily but I would say do it anyway if you haven't done it yet.
Old Jun 23, 2005 | 11:34 AM
Chris N's Avatar
No need unless you have an oil burning issue. Good numbers.
Old Jun 23, 2005 | 09:34 PM
Azcheron's Avatar
Default Re: COMPRESSION TEST! results....comments welcomed (Chris N)
i burn some oil, not too much though, or do i?
i burn like a quart every 2k miles
SilkyJohnson
13
Feb 15, 2011 05:54 PM
humboldt_skim
May 31, 2008 08:18 AM
climb_on
Jul 29, 2007 03:40 PM
John.
Jun 12, 2006 08:45 AM
Got_soy
28
Aug 8, 2005 12:49 PM
