Suspension & Brakes Theory, alignment, spring rates....
Clicking noise while making right turns
Old Jun 22, 2005 | 08:50 PM
ptran's Avatar
Default Clicking noise while making right turns
90 ex accord makes clicking noise on right turns. the noise is not present on straight aways. Any idea what i have to replace to get it back to optimal working condition?
I believe this is a pretty common problem with accords. My first accord had the same problem, brought it to an old school mechanic and he took care of it for me. forgot to find out what was the problem. plus it was a long time age too.
Old Jun 22, 2005 | 09:01 PM
slammed_93_hatch's Avatar
Default Re: Clicking noise while making right turns (ptran)
its your right side axel probably
Old Jun 22, 2005 | 09:35 PM
Brian Hinson's Avatar
I think its the left one actually
Old Jun 23, 2005 | 08:22 PM
ptran's Avatar
So replacement of the axle should fix the noise? Any input on the difficulty and is it DIY project?
Old Jun 23, 2005 | 08:45 PM
vtecvoodoo's Avatar
Future Texas Boy
torn boot
Old Jun 23, 2005 | 09:07 PM
blaster834's Avatar
torn boot could have caused this but you just cant replace the boot now you have to replace the whole axle
Old Jun 24, 2005 | 09:38 PM
ptran's Avatar
Default Re: (blaster834)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaster834 &raquo;</TD></TR><TR><TD CLASS="quote">torn boot could have caused this but you just cant replace the boot now you have to replace the whole axle</TD></TR></TABLE>
damn it. is this a DYI project?
Old Jun 27, 2005 | 06:49 PM
Default Re: (ptran)
sure take off the wheel,
take off the bottom fork for the damper, and disconect the spindel from the tie rod(i think thats were it attaches), take off the big axel nut and pull it out, repeat it in reverse
Old Jul 1, 2005 | 07:43 AM
Dustin L's Avatar
Default Re: (slammed_93_hatch)
Your CV joint is most likely trashed. Those are classic symptoms, and it will get progressively worse. If just the boot is torn, its time left is probably limited anyway and you should replace them both regardless. Especially with how cheap replacements are these days.
Old Jul 1, 2005 | 09:19 PM
gabebauman's Avatar
Default Re: (Dustin L)
Re-Manufactured axles are like $60 at CarQuest or AutoZone after you return the bad axle. It's a fairly straight forward install...that can be done in a couple of hours for a first timer. Good luck man.
Old Jul 1, 2005 | 09:44 PM
ptran's Avatar
Default Re: (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">Re-Manufactured axles are like $60 at CarQuest or AutoZone after you return the bad axle. It's a fairly straight forward install...that can be done in a couple of hours for a first timer. Good luck man. </TD></TR></TABLE>
YEA?! saw an ad in the marketplace forum for 340.00 OEM for both axles. For $60 each, I'm definately going with remanufactured.
Any one have access to DIY instructions and pictures?
Old Jul 4, 2005 | 12:02 AM
eMpAtHy's Avatar
Default Re: (ptran)
i've seen people break ratchets from trying to take off the axle nut...
1lowsol2
22
Feb 6, 2007 01:28 PM
B00ST2nR
Aug 6, 2006 06:32 AM
accordredliner
Dec 21, 2005 08:14 PM
WRTEG
Aug 18, 2004 02:15 PM
Simple
17
Jan 15, 2003 05:26 PM
