Hondata S200 with out boost option??
Old Jun 22, 2005 | 04:59 PM
BLWNB16A@11psi's Avatar
Default Hondata S200 with out boost option??
Is it possible to run a boosted car with just a S200 with out the boost option?
I have an exellent opportunity to purchase a S200 the guy says he has been running a low boost turbo set up on this @8 psi
that is great because I want to run about the same 10 psi
is this possible let me know
(has any one figured out how to decode the boost option in a hondata unit yet????)
thanx
Old Jun 22, 2005 | 05:04 PM
TheShodan's Avatar
Moderator
No. The boost option is needed for this. No way around it. You can always go to your local hondata dealer and add the option.
Old Jun 22, 2005 | 05:06 PM
dornon13's Avatar
Default Re: (TheShodan)
yeah you might as well keep the stock ecu if you want to do what you plan
Old Jun 22, 2005 | 07:58 PM
tub_sephiroth's Avatar
Default Re: (dornon13)
No you can't. When I bought my S200 w/boost, I didn't know that they didn't activate my boost option. Instead, they only gave me the code to unlock the boost option. So as I was trying to drive my car to my tuner, I had to hit boost a little bit getting on the freeway. As soon as my ecu sensed boost, my car shut down.
If you run a S200 without the boost option, as soon as your ecu sees boost, your car will shut down.
Old Jun 22, 2005 | 08:27 PM
RMS's Avatar
RMS
you are an ******* anyway for asking how to rip off a legitimate company. i say boost 20psi with the non-boosted unit for you.
may as well ask if anyone has found a way to get around the immobilizer so you can go steal a car.
HondAcura
Northeast (Sales)
Jul 14, 2006 03:37 AM
BlackThorN
Dec 21, 2003 12:51 AM
5thgencivic
Sep 17, 2003 06:41 PM
92HB_HB
Feb 13, 2002 07:26 AM
