P72 on a 00 Civic SI harness?
Old Jun 22, 2005 | 01:36 PM
JDM99Hatch's Avatar
Default P72 on a 00 Civic SI harness?
i hooked up my buddy's 96 Gs-R motor in his 00 SI using the exsiting SI harness because the ecu harness didnt come with the GSR motor, shouldnt a P72 be able to plug right into that harness or am i mistaken. I am used to doin type r swap and usin a chipped p28. this is first time i did a gsr swap he is runnin his SI computer right now so the motor isnt makin much power and i cant run the IAB on the si computer right?
Old Jun 22, 2005 | 01:58 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: P72 on a 00 Civic SI harness? (JDM99Hatch)
you gotta use an obd2b p72. obd2a p72 has different plugs for the ecu.
Old Jun 22, 2005 | 02:38 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: P72 on a 00 Civic SI harness? (AzntaggeR)
no you cant run the iab on the si computer. either get a 2b p72 or get a 2a to 2b jumper.
SkRiBLaH
12
Jun 23, 2006 05:43 PM
jdmkevin
Jun 18, 2003 06:13 PM
d0nkeyxPunch
Mar 16, 2003 12:05 PM
Chuji
Aug 23, 2002 07:03 AM
