Whats going on with my 5 lug brakes?
Old Jun 22, 2005 | 12:41 PM
jimmhatch's Avatar
Default Whats going on with my 5 lug brakes?
I got around installing a US Type R 5 lug conversion on my EK. I also swapped out for the 99-00 Civic Si prop valve, brake booster, and master cylinder. I have bleed the brakes 3 times now, once every weekend and the problem im having is my brake pedal is stiff as a rock. It goes only about half way and becomes hard as a rock. The brakes still work but I cannot stop suddenly. I can only brake slowly. When i push the brake pedal to the bottom to where I cannot push anymore when it becomes rock hard, the car slowly slows down. Whats going on and have anyone ever experience this or know how to fix the problem?
Old Jun 22, 2005 | 01:39 PM
JDM99Hatch's Avatar
Default Re: Whats going on with my 5 lug brakes? (jimmhatch)
I have a 5lug on both my EK's i just put them on with braided lines , you dont need to replace all that stuff like the master cyl and pro. valve, i dont kno why your having that problem though, thats wierd.
Old Jun 22, 2005 | 01:41 PM
A.E Motoring's Avatar
Default Re: Whats going on with my 5 lug brakes? (JDM99Hatch)
change everything back to stock...mc pp and bb...see if it feels any better
Old Jun 22, 2005 | 02:41 PM
boostedcivicsir's Avatar
Mr. Badwrench
this is stupid, but you do have the booster hooked up to the manifold? and the check valve is in correctly? sounds like you have no power assist. swap out the boosted back to stock and try that. you may have a ripped diaphragm in the booster.
Old Jun 22, 2005 | 06:48 PM
jimmhatch's Avatar
Default Re: Whats going on with my 5 lug brakes? (boostedcivicsir)
I have everything plugged up. The stock booster and MC, prop will work wtih 4 wheel disk? I thought a bigger mc will have the brakes working better.
Old Jun 22, 2005 | 06:58 PM
wheels01's Avatar
A bigger master cylinder needs higher pedal effort to stop. But in turn creates more braking power. Double check that the spring clip on your brake pedal arm is installed into the brake booster properly, might be hitting something to cause it to stop. Another suggestion and this might sound stupid is pull the ebrake a bunch of times, this should bring the rear brake cylinders and pads into the rotor. The last thing to try is check the brake booster. Hayes manuals have a good right up on how to do this without removing anything. That would help you rule it out.
Old Jun 22, 2005 | 08:26 PM
EricUSC's Avatar
Default Re: Whats going on with my 5 lug brakes? (wheels01)
My brakes felt too mushy after the ITR brakes/mc/booster were installed. The mechanic told me to drive it for a couple weeks and the mushiness will go away and it did. I guess that the new parts have to break in.
Try driving for a couple of weeks and see if your brake pedal feel improves.
Old Jun 22, 2005 | 11:29 PM
jimmhatch's Avatar
Default Re: Whats going on with my 5 lug brakes? (EricUSC)
im getting type r BB,and MC in the mail soon. I will try those. IF the problem still happens then I will go back to stock.
Old Jun 23, 2005 | 12:53 AM
CivicSiRX's Avatar
the bb is the same in all eks. should of just to the Si mc and prop valve and ur good to go.
on my friends ek, we setup gsr all round disc with si mc and prop with stock dx bb. brakes work very very well. doesnt even go halfway.
Old Jun 25, 2005 | 06:31 AM
jimmhatch's Avatar
Default Re: (CivicSiRX)
my brakes work like a charm, swapped out for the type r brake booster and 1 inch master cylinder. Thanks everyone for your help
Ueichi
Feb 25, 2011 02:25 PM
gearhead313
Sep 17, 2007 09:44 AM
ejcivicdee
Suspension & Brakes
Apr 11, 2007 07:56 PM
hialeahzbg
20
Apr 29, 2006 06:01 PM
Del_Sol_s
27
Mar 4, 2006 06:49 AM
