What is a safe boost level for a JDM GSR motor?
I think its safe to assume that your rods/pistons/sleeves are stock. If so keep it around 8psi on the turbo. If you have rods/pistons keep it around 300whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc »</TD></TR><TR><TD CLASS="quote">I think its safe to assume that your rods/pistons/sleeves are stock. If so keep it around 8psi on the turbo. If you have rods/pistons keep it around 300whp.</TD></TR></TABLE>
Yeah, sorry. The block/head are stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD »</TD></TR><TR><TD CLASS="quote">You can easily run 10Psi on a good tune. The better the tune the more boost.</TD></TR></TABLE>
Ok, I'll order my 10psi spring today. I don't plan on running 10psi all the time, just getting ready for "battle" next month.
Tuning w/ race gas is scheduled soon. I'll be sure to post my results
Thanx guys
Thanx guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChronicGreenDC2 »</TD></TR><TR><TD CLASS="quote">
Thanx guys
if you dont want to run 10 psi all the time why are you running a 10 psi base spring? get a .5 or .6 bar then use a boost controller so you have a means of lowering it. thats just my o.o2
Thanx guys
</TD></TR></TABLE>if you dont want to run 10 psi all the time why are you running a 10 psi base spring? get a .5 or .6 bar then use a boost controller so you have a means of lowering it. thats just my o.o2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">
if you dont want to run 10 psi all the time why are you running a 10 psi base spring? get a .5 or .6 bar then use a boost controller so you have a means of lowering it. thats just my o.o2</TD></TR></TABLE>
Yeah, thats the plan, but I can't afford an electric boost controller right now, and I don't wanna deal w/ a manual one. So a $30.00 spring will hold me over till I save $300.00 for a profec-B
So it would be easy to make 300 WHP on 10PSI on a totally stock gsr? <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">10 psi with tunning is about 300whp easy.</TD></TR></TABLE>
Compression is 10:6 so its pretty much the same as a USDM Type R, although i belive the ring lands are alot more robust. Same engine as mine.
Personally id tune 6psi ish, get that sorter and see how it runs etc, then get a 10psi spring if you dont wanna run 10 all day but cant afford a EBC and swap the springs at track (BOTH boost pressures need tuning)
today I did a compression test to see how healthy the motor was. I followed the directions from the C-speed site and I came up w/ 220psi across the board (give or take a hair or two) nothing within 5psi on each other. I couldn't believe it, so I tested again, same results.
C-speed sayz 5 cranks, but I noticed the more I cranked it the higher the gauge went. The numbers I used were off the 5 crank spot.
I just hope I did it right. I'm gonna post my results on some compression test threads, I thought I would just let you guys know.
ANOTHER QUESTION .... HOW BOUT A GSR WITH STOCK SLEEVES BORED TO 81.5MM and it has blockguard , cp pistons , eagle rod's ............. could u take it to 20 psi ? with some good tuning ? would it be safe ....
what c/r are the pistons?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGSR »</TD></TR><TR><TD CLASS="quote">ANOTHER QUESTION .... HOW BOUT A GSR WITH STOCK SLEEVES BORED TO 81.5MM and it has blockguard , cp pistons , eagle rod's ............. could u take it to 20 psi ? with some good tuning ? would it be safe ....</TD></TR></TABLE>
Theres a guy running around (with a good tune) with 17lbs daily and like 25 or so LBS when he races. He has a the stock sleeves with some forged pistons and rods. I also belive the motor is a GSR.
the.hamburglar
Sep 29, 2005 05:59 AM
DA MUGEN 1
Dec 24, 2003 08:12 AM
anyways i had mine tuned at solid technology in abq.
