Timing for a turbo car
Nice question.
16 base ignition timing then retard .75 degree's per psi of boost. Of course you won't know optimum timing to be at unless you are on a dyno.
https://honda-tech.com/zerosearch
37 degrees at 22 PSI and You'll be set.......for a new engine.
Dyno tuning is the only way and not every engine reacts the same way on the same timing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">37 degrees at 22 PSI and You'll be set.......</TD></TR></TABLE>
Sounds about right for an H22
