aftermarket wild cams for my B16 that have STOCK non-VTEC lobes???
Old Jun 22, 2005 | 10:14 AM
EKCRX-Ihadastupidusername's Avatar
Default aftermarket wild cams for my B16 that have STOCK non-VTEC lobes???
Which company makes such a cam? I want Toda Spec C type topend, but factory non-VTEC lobes. I don't care about low, or even too much about mid range power. The reason for VTEC is to have docile car with good MPG, yet have *** ripping power up top, with NO compromises. I believe that wild cams with wild non-VTEC lobes are defeating the purpose of VTEC. I also don't want to have to "tune" lope out of the idle, or reduced MPG, or any of that crap. If my power band is 7500+, fine.
I'm going with an all-motor, daily driver. but, I still want peaky power, 11K RPM, a Hulk leg inducing clutch, and that magic sound of a cammed NA Honda B series in VTEC.
Old Jun 22, 2005 | 10:52 AM
Kidnkorner's Avatar
Default Re: aftermarket wild cams for my B16 that have STOCK non-VTEC lobes??? (diegoaccord)
i can't remember which company it is, or maybe its both. Crane or Crower can do a custom grind. You will have to know what lift and duration you want for the center high RPM Lobe, and specify stock Low RPM lobe.
Racewerkz
11
Dec 27, 2010 09:27 AM
lude98SH
Jul 20, 2008 08:05 AM
GSRCRXsi
Oct 24, 2006 03:03 PM
JinMTVT
12
Dec 21, 2004 08:31 PM
miksew
15
Sep 19, 2003 08:29 AM
