aftermarket wild cams for my B16 that have STOCK non-VTEC lobes???
Which company makes such a cam? I want Toda Spec C type topend, but factory non-VTEC lobes. I don't care about low, or even too much about mid range power. The reason for VTEC is to have docile car with good MPG, yet have *** ripping power up top, with NO compromises. I believe that wild cams with wild non-VTEC lobes are defeating the purpose of VTEC. I also don't want to have to "tune" lope out of the idle, or reduced MPG, or any of that crap. If my power band is 7500+, fine.
I'm going with an all-motor, daily driver. but, I still want peaky power, 11K RPM, a Hulk leg inducing clutch, and that magic sound of a cammed NA Honda B series in VTEC.
Re: aftermarket wild cams for my B16 that have STOCK non-VTEC lobes??? (diegoaccord)
i can't remember which company it is, or maybe its both. Crane or Crower can do a custom grind. You will have to know what lift and duration you want for the center high RPM Lobe, and specify stock Low RPM lobe.
GSRCRXsi
10-24-2006 03:03 PM
JinMTVT
12
12-21-2004 08:31 PM
miksew
15
09-19-2003 08:29 AM
