gsr 2.0 vs. lsvtec 2.0
Old Jun 22, 2005 | 07:00 AM
highrevnef's Avatar
Default gsr 2.0 vs. lsvtec 2.0
i just got done building my b16 head and im am now moving onto the block. im debating between a gsr 2.0 or an lsvtec 2.0. both blocks are gonna be sleeved. which would be a better set up. and its all going into a 91 hatch.
Old Jun 22, 2005 | 07:08 AM
Big Teggie's Avatar
Default Re: gsr 2.0 vs. lsvtec 2.0 (highrevnef)
The LS will have more displacement because of the stroke.
The GSR will have less and a girdle for the mains.
Old Jun 23, 2005 | 03:45 AM
StorminMatt's Avatar
Default Re: gsr 2.0 vs. lsvtec 2.0 (Big Teggie)
You cal always use the LS crank and rods in a GSR block for the same same displacement, though. But with the GSR crank and rods, the motor will rev better and wear less.
Old Jun 23, 2005 | 04:04 AM
Chillinit's Avatar
personally, I would go with a 2.0L gsr.
Old Jun 23, 2005 | 06:05 AM
Rollo Lawson's Avatar
Default Re: gsr 2.0 vs. lsvtec 2.0 (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">personally, I would go with a 2.0L gsr. </TD></TR></TABLE>
only if he has both blocks in his possesion. if you have to purchase a b18c1 to sleeve it, then its a no-brainer. lsv all the way.
Old Jun 23, 2005 | 07:43 AM
huepowered's Avatar
Default Re: gsr 2.0 vs. lsvtec 2.0 (B16C1)
the displacement is the same on both. 2.0 is 2.0.. that's like saying
which one has more volume?
a 1 liter of soda or a liter of milk?
now if he's talking about 84mm bore for his block, that's a different story
i would personally go with the gsr block
Old Jun 23, 2005 | 08:34 AM
Default Re: gsr 2.0 vs. lsvtec 2.0 (huepowered)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huepowered &raquo;</TD></TR><TR><TD CLASS="quote">the displacement is the same on both. 2.0 is 2.0.</TD></TR></TABLE>
you think so? stroke is a determining factor of the powerband. your st8ment is wrong. the gsr will peak later and possibly make more peak hp. but, the ls will make more overall power. some people love to rev, others just want the most usable power. every 2L is not the same, or should i say..... does not have the same characteristics.
Old Jun 23, 2005 | 08:51 AM
ne3ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16C1 &raquo;</TD></TR><TR><TD CLASS="quote">
you think so? stroke is a determining factor of the powerband. your st8ment is wrong. the gsr will peak later and possibly make more peak hp. but, the ls will make more overall power. some people love to rev, others just want the most usable power. every 2L is not the same, or should i say..... does not have the same characteristics. </TD></TR></TABLE>
I think what he is trying to say that if both are 2.0's then they are both 2.0's
if they both had 84 mm bore
gsr: 1933cc
LS: 1973cc
the gsr would be closer to a 1.9 and the ls would be a 2.0 get it?
So the gsr would need more bore to reach the same displacement as the LS
The GSR would have the better rod ratio however. Ls would make more tq but GSr would last longer.
Old Jun 23, 2005 | 09:11 AM
highrevnef's Avatar
Default Re: gsr 2.0 vs. lsvtec 2.0 (ne3ek)
wut do u think about a crvtec with a sleeved block. how would u compare that to an lsvtec 2.0?
Old Jun 23, 2005 | 09:56 AM
Chip's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrevnef &raquo;</TD></TR><TR><TD CLASS="quote">wut do u think about a crvtec with a sleeved block. how would u compare that to an lsvtec 2.0?</TD></TR></TABLE>
It's exactly the same thing.
Old Jun 23, 2005 | 09:59 AM
ne3ek's Avatar
Default Re: gsr 2.0 vs. lsvtec 2.0 (Chip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chip &raquo;</TD></TR><TR><TD CLASS="quote">
It's exactly the same thing.</TD></TR></TABLE>
correct, a sleeved 84mm ls is the same as a sleeved 84mm crv
Old Jun 23, 2005 | 10:13 AM
JerseySiPOS's Avatar
im using an LS crank in a gsr block. With an ls crank generally peak tq will be a few rpms earlier in the powerband compare to a gsr crank, because of the rod/stroke ratio.
I put an engine combo together to keep engine speeds below 9000 rpms, so it works for me. If you have a gsr block with the crank, use it. Up to you. You just have to decide what area of the powerband you want to emphasize.
1999siguy
May 14, 2009 03:06 PM
SwappedTURBOegg
Sep 13, 2005 04:55 PM
slambedcivic
Jul 14, 2005 05:05 AM
mrDFWmechanic
Apr 10, 2005 03:07 PM
