My first swap HElP
Old Jun 22, 2005 | 06:44 AM
Slava.'s Avatar
Default My first swap HElP
I have an EK shell that I'm putting a obd1 b18c1 into. From what I've read so far people use a 96-98 ex wirenig harnesses and others use a 99-00 SI wireing harnesses. What would you recomend and why? And yes I did SEARCH
Old Jun 22, 2005 | 08:53 AM
Slava.'s Avatar
Anyone?
Old Jun 22, 2005 | 06:14 PM
vsmhatched's Avatar
Default Re: My first swap HElP (1.8-VSM-EK)
you should use the harness that your car is whether its 96-98 (obd2a) or 99-00 (obd2b) and use obd2 injectors and change the plug on the alternator and use a obd2 dizzy. You can use the Dizzy housing off of the B18C but just switch the insides, you know what i mean. Just run obd2 and you can get a jumper harness for a obd1 ecu. Thats what my friend did with his EK with a obd1 LS
Old Jun 23, 2005 | 06:10 AM
Slava.'s Avatar
Default Re: My first swap HElP (GreyDel)
Cool thanks.
Old Jun 23, 2005 | 06:08 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel &raquo;</TD></TR><TR><TD CLASS="quote">You can use the Dizzy housing off of the B18C but just switch the insides, you know what i mean.</TD></TR></TABLE>
Actually the internals of an OBD1 and OBD2 distributor are the same, simply changing the plug style is all that is needed.
JdmAcclude
Jan 8, 2012 07:26 PM
be18see1
Apr 1, 2007 08:58 AM
EGhatch33
Jan 12, 2007 09:54 AM
98JDM_Type_R
Aug 19, 2004 01:51 PM
