Exhaust size
Old Jun 22, 2005 | 06:25 AM
Blabla01's Avatar
Default Exhaust size
What is the exhaust size... Civic cx 1996 vs Integra rs 2000 ?
Thanks!
Old Jun 23, 2005 | 07:32 AM
Blabla01's Avatar
up !!!
Old Jun 28, 2005 | 05:27 PM
Blabla01's Avatar
bump!
Old Jun 29, 2005 | 01:46 PM
Blabla01's Avatar
help plzzzzz!!
Old Jun 29, 2005 | 01:50 PM
Farmer Brown's Avatar
Default Re: (RiceMe)
Are you talking stock? or best performing size.
Old Jun 29, 2005 | 02:00 PM
mike81's Avatar
Default Re: (Djaric)
that sucks u just wasted four of ur five posts for the day.....that was kind of a bump for u i guess?
Old Jun 29, 2005 | 02:29 PM
Blabla01's Avatar
Stock exhaust size.
Old Jun 29, 2005 | 02:45 PM
EK k kay's Avatar
Stock 96 CX is about 1.75" OD. The ID should be just a bit smaller.
Old Jun 29, 2005 | 02:48 PM
Blabla01's Avatar
Integra?
Old Jun 29, 2005 | 09:14 PM
Just a bit larger but less then 2" I believe.
Old Jun 30, 2005 | 05:32 AM
Blabla01's Avatar
If I swap a B18b into my EK it's ok or the exhaust is too small?
Old Jun 30, 2005 | 09:16 PM
Blabla01's Avatar
up
Old Jun 30, 2005 | 10:27 PM
MiMiK's Avatar
if you swap in a b18b, you should have the exhaust changed. i don't even think it lines up...
Old Jul 1, 2005 | 06:18 AM
SpydiR's Avatar
Default Re: (MiMiK)
it will line up, but you should definitely work on getting an exhaust system on that thing before anything else
Old Jul 1, 2005 | 05:52 PM
boricua_SSL13's Avatar
Default Re: (SpydiR)
yeh the small exhaust will slow u down but not that much. and it does line up...if u cant rotate the cat convertor then u can heat the piping and turn it...you would want a 2 1/4 - 2 1/2 inch exhaust depending on ur setup...hope that helps
MEGAME EXHAUST
Welding / Fabrication
May 3, 2011 12:25 PM
BIG T
Jan 30, 2010 03:24 PM
efn91
Feb 17, 2009 10:53 AM
94dxt
Mar 28, 2003 02:18 PM
