Fouling plugs
Old Jun 22, 2005 | 05:29 AM
PearlWhiteAccord's Avatar
Default Fouling plugs
engine keeps getting flooded w/ fuel...
pls help...plugs foulded...
Old Jun 22, 2005 | 05:34 AM
JDM-EJ1's Avatar
Default Re: Fouling plugs (PearlWhiteAccord)
You're going to need to post up more information. How are your spark plugs (I'm assuming that's what you mean when you say 'plugs').
Have you taken them out? Are any of them miscolored?
Old Jun 22, 2005 | 05:47 AM
b204dr's Avatar
are you getting any spark - it could be the plugs wires , cap & rotor or dizzy it self . There are many more things -
Old Jun 22, 2005 | 06:34 AM
Default Re: (b204dr)
gettin spark, since i checked w/ the screwdriver trick....
plugs are black...
Old Jun 22, 2005 | 06:36 AM
JDM-EJ1's Avatar
Default Re: (PearlWhiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlWhiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">gettin spark, since i checked w/ the screwdriver trick....
plugs are black...</TD></TR></TABLE>
Are all the plugs black? Or just certain ones?
Replace the plugs ASAP.
Old Jun 22, 2005 | 06:40 AM
Default Re: (JDM-EJ1)
did it last sunday...it started up and drove for 20 miles...
now its doing the same ****....
getting black on all 4
Old Jun 22, 2005 | 07:43 AM
extra cam needed's Avatar
From: americas finest, calee fourn ya, united states
Is the black soot on them just dry and sooty or does it have an oily soot to it?
Old Jun 22, 2005 | 08:08 AM
b204dr's Avatar
sounds like could be detonation or bad rings! oil seeping up onto the plug !
Old Jun 22, 2005 | 08:13 AM
dry and sooty....should be too much fuel in the chambers...
Old Jun 22, 2005 | 08:29 AM
another thing is that when i took off gas cap, lot of pressure came out...
Old Jun 22, 2005 | 08:49 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlWhiteAccord &raquo;</TD></TR><TR><TD CLASS="quote">another thing is that when i took off gas cap, lot of pressure came out...</TD></TR></TABLE>
That happens in my Accord when I have gas left in there and I'm filling up. I never think twice about it.
Old Jun 22, 2005 | 08:56 AM
i guess that is normal, then
Old Jun 22, 2005 | 09:59 AM
b204dr's Avatar
dry and sooty - ok i thought fuel wasnt burning maybe blackening due to oil mixture -
Old Jun 22, 2005 | 10:04 AM
O16581724 5 2 5's Avatar
Did your engine just start suddenly doing this, or was it after a certain event?
Old Jun 22, 2005 | 11:20 AM
Default Re: Fouling plugs (x O 16581 72452 5 x)
it just happend on sunday, and plugs were replaced, started fine but after driving for 20 miles the next day, it died out after 5 seconds at idle...and now, it just cranks
Old Jun 22, 2005 | 11:47 AM
b204dr's Avatar
It only cranks hmm that sounds worse than me with my bad ring ! lol my runs on 3 but yea i think change the plugs wires cap rotor - if its not there try comp testing it
Old Jun 22, 2005 | 11:54 AM
all looked ok to me.....and i get spark form the wires w/ screwdriver to ground test...so i doubt it is my distributor..
Old Jun 22, 2005 | 12:47 PM
EE_Chris's Avatar
What's the setup? Is this a stock car?
Old Jun 22, 2005 | 12:51 PM
Default Re: Fouling plugs (EE_Chris)
93 Sol si auto, Stock w/ intake only
Old Jun 22, 2005 | 12:59 PM
EE_Chris's Avatar
How many miles on the cap, rotor, plugs and wires? Did this problem just come out of no where or has it been an ongoing problem for awhile?
Old Jun 22, 2005 | 01:00 PM
Came out of no where...was driving fine till last week, brought to mechanic and they changed plugs, started back up to normal then ended up the same problem
Old Jun 22, 2005 | 04:33 PM
OK, got home, wiped dry my plugs from the fuel....tested all 4 wires w/ plugs grounded to chasis, all had sparks..
car started up for 5 seconds and dies..
took out plugs again, and plugs were a bit moist w/ fuel...
hence plugs are shutting off spark since too much fuel spraying in..
anyone know why??? please help, i called my mechanic and he said could be sensor, timing or injectors...can anyone confirm??
Old Jun 22, 2005 | 05:12 PM
f1z1c's Avatar
Check your timing belt?
Old Jun 22, 2005 | 05:13 PM
f1z1c's Avatar
Could be Air Intake Temp sensor going haywire. Is she throwing codes?
EGhatchLSV
Jan 31, 2008 02:01 AM
numotive
Aug 4, 2005 11:26 AM
b16powwer
Aug 7, 2003 10:10 PM
MikeMAN
Jan 16, 2003 11:38 AM
