Fouling plugs
Imperious: Mod of Valor
Re: Fouling plugs (PearlWhiteAccord)
You're going to need to post up more information. How are your spark plugs (I'm assuming that's what you mean when you say 'plugs').
Have you taken them out? Are any of them miscolored?
Re: (PearlWhiteAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlWhiteAccord »</TD></TR><TR><TD CLASS="quote">gettin spark, since i checked w/ the screwdriver trick....
plugs are black...</TD></TR></TABLE>
Are all the plugs black? Or just certain ones?
Replace the plugs ASAP.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PearlWhiteAccord »</TD></TR><TR><TD CLASS="quote">another thing is that when i took off gas cap, lot of pressure came out...</TD></TR></TABLE>
That happens in my Accord when I have gas left in there and I'm filling up. I never think twice about it.
Re: Fouling plugs (x O 16581 72452 5 x)
it just happend on sunday, and plugs were replaced, started fine but after driving for 20 miles the next day, it died out after 5 seconds at idle...and now, it just cranks
It only cranks hmm that sounds worse than me with my bad ring ! lol my runs on 3 but yea i think change the plugs wires cap rotor - if its not there try comp testing it
How many miles on the cap, rotor, plugs and wires? Did this problem just come out of no where or has it been an ongoing problem for awhile?
Re: Fouling plugs (EE_Chris)
Came out of no where...was driving fine till last week, brought to mechanic and they changed plugs, started back up to normal then ended up the same problem
OK, got home, wiped dry my plugs from the fuel....tested all 4 wires w/ plugs grounded to chasis, all had sparks..
car started up for 5 seconds and dies..
took out plugs again, and plugs were a bit moist w/ fuel...
hence plugs are shutting off spark since too much fuel spraying in..
anyone know why??? please help, i called my mechanic and he said could be sensor, timing or injectors...can anyone confirm??
b16powwer
08-07-2003 10:10 PM
