Who makes the best ignition upgrade?
Old Feb 12, 2002 | 11:59 AM
jonnybravo's Avatar
Default Who makes the best ignition upgrade?
What types of gains in numbers if possible have you seen or produced?
Old Feb 12, 2002 | 12:00 PM
jonnybravo's Avatar
Default Re: Who makes the best ignition upgrade? (jonnybravo)
up
Old Feb 12, 2002 | 12:16 PM
sgT's Avatar
sgT
stick with stock
Old Feb 12, 2002 | 12:22 PM
newt2's Avatar
INSERT TITLE HERE
25 Year Member
Community Builder
Default Re: Who makes the best ignition upgrade? (sgT)
Everyone I know with an aftermarket ignition has had trouble.
Old Feb 12, 2002 | 12:25 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Why do you want an aftermarket ignition system? for more hp? Do what sgT said.
Old Feb 12, 2002 | 12:27 PM
sgT's Avatar
sgT
Default Re: Who makes the best ignition upgrade? (Dave-ROR)
The only time i have seen it necessary is with forced induction or real high comp
ratio situations
Old Feb 12, 2002 | 12:34 PM
Willard's Avatar
because it looks cool..
MASTER BLASER EXTERNAL COIL WILL GIVE YOU 1.9% more power and 3.2% more fuel economy...
Will
-with OEM high tension leads/fire generation system...
Old Feb 12, 2002 | 01:56 PM
JPP's Avatar
JPP
The first modification I did on my ITR, when I was young and naive, was the Jacobs Electronic ingnition system. Two days after the installation, the car would not start, I tried every spark plug gapping imaginable and it just would not start.
Three days after the installation, the ignition system was on it's way back to Jacob's Electronic for a full refund (minus shipping cost). As soon as I plug the stock ignition system back on the car started right away.
Conclusion: The first modification I did on my ITR was to give money to the shipping company.
Stay with stock
Old Feb 12, 2002 | 06:46 PM
JohnnyBoy's Avatar
Default Re: Who makes the best ignition upgrade? (JPP)
Not needed unless you have a crazy engine....waste of money.
Old Feb 12, 2002 | 08:32 PM
AJ PwR's Avatar
Ultra MDI direct fire system
Old Feb 12, 2002 | 10:29 PM
RineRacing's Avatar
Electromotice TEC3 systems are supposed to be very good, but you better know what you're doing.
Old Feb 13, 2002 | 02:04 AM
EGtoR's Avatar
Default Re: Who makes the best ignition upgrade? (AJ PwR)
Is the Ultra MDI available in Canada? How much are they and how do they work? Is there a pre-set program that come with it for the ITR or I need to program it myself?
Old Feb 14, 2002 | 05:22 PM
AJ PwR's Avatar
Default Re: Who makes the best ignition upgrade? (EGtoR)
This is actually not available in Canada. The MDI uses your stock sensors inside the distributor for readings. These signals are processed and amplified finally arriving to the included direct fire coils. This eliminates the use of the weaker stock coil entirely and has a theory like the new Hondas where ther is no distributor. It is all plug and play and ready made for Honda application. There is no trick in installation. Results are better ignition, leaner air/fuel ratios, better economy, much smoother power delivery low end and large high end power difference (from my butt dyno). Please email me or IM me for a price.
[Modified by AJ PwR, 6:24 PM 2/14/2002]
Old Feb 14, 2002 | 05:52 PM
TodaSi's Avatar
Default Re: Who makes the best ignition upgrade? (Willard)
Yep, waste of money. BTW, if you do get one for some unknown reason, don't get shocked by it......it ****n hurts
Old Feb 15, 2002 | 10:03 PM
Keyed ITR's Avatar
Default Re: Who makes the best ignition upgrade? (TodaSi)
The only thing I noticed with the Jacob's Pak was quicker revs, you can notice a small gain in high end power I suppose. I can't feel it anymore though, I hate it when that happens, then I keep spending money on modifications, then I'm broke.
Old Oct 9, 2011 | 07:03 PM
sir.rexington's Avatar
what about my motor? it's b18a1 10.7:1 ported head itb obd1
i know it's not the craziest but is it crazy enough?
Old Oct 10, 2011 | 03:42 AM
ekcoupeh22's Avatar
I'm Gunna be going the coil on plug route using full aem componets but I'm also running a big turbo
Old Oct 11, 2011 | 06:43 PM
Louie's Avatar
What would Chente do?
Holy 2002 Batman! Back from the dead.
Old Oct 12, 2011 | 12:35 AM
HYREV2NR's Avatar
Yeah for real! But I'll throw in my $.02 while I'm here.
The Jacobs system I had on an old 92 EG and it was junk! For the $$ MSD is the way to go. You will notice a little better throttle response but it's really not something to rave about.
I think it better works with a heavily boosted motor but on an N/A C5 I'd say you'd come out better buying a nice header.
Old Oct 12, 2011 | 06:34 AM
Todd00's Avatar
I said I don't want a title!
Why not try asking a new question in the proper forum instead of bumping an old thread from 2002 that is in the ITR forum?
Obviously you have little to nothing in common with what the discussion was about (almost 10 years ago).
eg:R
Sep 28, 2014 02:57 PM
petermartin
Dec 11, 2009 07:59 AM
mountainrich
Classic Hondas
Jul 12, 2009 02:50 PM
jmeyer99
Apr 29, 2008 02:29 PM
austrian type-R
Jul 3, 2003 08:42 AM
