overheating questions
Old Jun 21, 2005 | 10:59 PM
05em2's Avatar
Default overheating questions
ok recently noticed a small amount of white smoke coming out of the top of the radiator, smelled funny, thinking nothing of it, (flame suit on) i drive to work (25 miles away)...then i notice that car is very much reaching the red area in the meter that measures how hot the engine is....it's overheating, so i check and there's no coolant so i top that off and everything's ok....but today driving to work same thing happened car got real hot again like 80% to that red line...and i also noticed my radiator fan is not spinning....
i checked the "Fan" 15a fuse in the engine bay, it's fine...any other fuses? anyone know how much radiators run for, oem and aftermarket? any reccomendations?
also.....my blower is not working, has anything to do with rad faN?
Old Jun 21, 2005 | 11:04 PM
Jimmy's Avatar
Global Moderator
The radiator fan doesn't stay on all the time.. Did you give it a couple minutes or wait a little while to see if it was going to kick on?
Also your over heating problem could be a sticking t-stat or just time to upgrade to a dual core radiator.
Old Jun 21, 2005 | 11:07 PM
05em2's Avatar
Default Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">The radiator fan doesn't stay on all the time.. Did you give it a couple minutes or wait a little while to see if it was going to kick on?
Also your over heating problem could be a sticking t-stat or just time to upgrade to a dual core radiator.</TD></TR></TABLE>
yea i waited till engine was at full operating temp...fan still doesnt come on....dual core rads....ill give it a search....
can you give me more in fo on the sticking thermostat...im also gonna do a search
Old Jun 22, 2005 | 11:14 AM
05em2's Avatar
Default Re: (Jay-Dee-Em)
search tool is good, i got tons of info, anyone wana say anything though?
Old Jun 22, 2005 | 11:24 AM
northkai3's Avatar
check the radiator cap! c if its broken
Old Jun 22, 2005 | 03:29 PM
05em2's Avatar
Default Re: (northkai3)
ok upper radiator hose is hot, and lower one is just warm, so from what ive read im guessing my thermostat is stuck shut or something....which is causing my fan not to spin, right?which in turn is causing my engine to overheat....am i correct, will gettting a new thermostat fix this?
Old Jun 22, 2005 | 03:37 PM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
thermostat
Old Jun 22, 2005 | 03:48 PM
05em2's Avatar
Default Re: (walker111)
so thermostat is the reason why my rad fan is not spinning right?? or do i need a new radiator too?
Old Jun 22, 2005 | 03:49 PM
98b18black's Avatar
Hopefully your thermostat...Possibly a head gasket....See what the new thermostat does...
Old Jun 22, 2005 | 03:53 PM
05em2's Avatar
Default Re: (95d15red)
nooo dont say headgasket i dont wanna change that!!! please god no!
but nobody answer the question?
will bad thermostat stop rad fan from activating?
Old Jun 22, 2005 | 04:10 PM
fasthatchb18c1's Avatar
yeah most likely it is your thermostat. If your lower hose is warm it is opening a little but not enough. There is a sensor right after the thermostat and when the thermostat fully opens it heats the sensor to trigger the fan. Get a new thermostat
Old Jun 22, 2005 | 11:09 PM
05em2's Avatar
Default Re: (fasthatchb18c1)
cool, i hope this fixes it, it's hella cheap....hope its not the headgasket or radiator cuz im low on cash right now cuz of damn school
pyrojeff
Oct 21, 2019 09:50 AM
Monotremata
May 18, 2011 05:21 PM
landon.alder
14
Aug 6, 2009 02:53 PM
kento
Jul 16, 2001 05:15 PM
