more on the hondata manifold gasket
Old Feb 12, 2002 | 11:39 AM
Doctor CorteZ's Avatar
Default more on the hondata manifold gasket
ok so could it be possible that the gasket serves no cooling purposes but when all the antifreeze is removed from the manifold that is what is showing the large temp differences?
so has anyone just looped the coolant lines back into the block and shown any cooler temps?
i have been told that the iac only needs cooling to keep it from freezing but what about the fast idle thermo switch - does it need coolant to function properly or would you just lose your fast idle when the car is cold ?
any info on this topic would be nice.
thanks - Jamie
Old Feb 12, 2002 | 11:45 AM
sgT's Avatar
sgT
Default Re: more on the hondata manifold gasket (Doctor CorteZ)
the older gaskets had the coolant bypass hole still intact and it still made
a noticable difference.
the fast idle valve needs coolant to function properly so I just remove it
completely. Its not really necessary and it isnt even used on the newer cars.
Old Feb 12, 2002 | 12:03 PM
EGtoR's Avatar
Default Re: more on the hondata manifold gasket (sgT)
So I can just drill a hole in the Hondata gasket to keep the coolant flow through?
Old Feb 12, 2002 | 12:08 PM
sgT's Avatar
sgT
Default Re: more on the hondata manifold gasket (EGtoR)
yes, but its better not to
Old Feb 12, 2002 | 12:10 PM
EGtoR's Avatar
Then what should I do with all those coolant lines? Just block it off? Actually, how many coolant lines I need to block off?
Old Feb 12, 2002 | 12:19 PM
sgT's Avatar
sgT
i said in the other thread to "T" the heater hose from the head and route that to
the thermostat housing
Old Feb 12, 2002 | 12:26 PM
EGtoR's Avatar
Then what are the other benefit for blocking the coolant line beside make it run cooler? Also, is there any disadvantage to it?
Old Feb 12, 2002 | 12:33 PM
sgT's Avatar
sgT
no disadvantage really.
more disadvantages leaving it where it is
Old Feb 12, 2002 | 03:43 PM
EGtoR's Avatar
I see, but will I have problem in cold weather like -20 C if I block off the coolant line?
BTW, when will your groupbuy on this start?
Old Feb 12, 2002 | 08:15 PM
sgT's Avatar
sgT
You will only have problems with cold start. But does it REALLY get THAT cold
in Ont?? Thats really cold. But once the car warms up its fine.
You could always just run coolant to the IAC if you worry about it that much.
Old Feb 13, 2002 | 01:53 AM
EGtoR's Avatar
What kind of problem I will have with cold start? It does get that cold here once in awhile, and I need my car everyday. You know, I don't want to call in to skip work because my modified ITR cannot start up due to too cold, but other people with a 91 Civic started up with no problem.
hughesl
Apr 30, 2005 01:51 PM
BahamaEKcrvtec
Dec 11, 2004 04:40 PM
Sinner
May 29, 2003 10:41 AM
Jared
Jun 17, 2002 12:01 PM
