Greddy turbo timer not working correctly on my 88 HF?
Well I guess I hooked up everything correctly...
red - white
blue - yellow
green - yellow / black
brown - e-brake
and I havent hooked up the purple to the speedo sensor or some ****....but what I dont understand is how come my **** doesnt work? It turns on and everything but the thing is when i shut off the car. The turbo timer just shuts off with it....instead of you know, staying on and shutting my car afterwards.
Any ideas?
red - white
blue - yellow
brown - e-brake
Any ideas?
Sounds like the ebrake wire. I know you have it hooked up, but just ground the thing temporarly to see if that fixes it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Sounds like the ebrake wire. I know you have it hooked up, but just ground the thing temporarly to see if that fixes it.</TD></TR></TABLE>
I have the timer grounded as well. I'm stumped, any ideas?
Ground the brown wire? I thought you didnt need to have the brown wire to work? Isn't it just an option? Like the purple wire?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">Ground the brown wire? I thought you didnt need to have the brown wire to work? Isn't it just an option? Like the purple wire?</TD></TR></TABLE>
Yea that's what I meant. Not an option, learned this going through the same situation you are
I usually just ground it instead of hooking it up to the ebrake.
I usually just ground it instead of hooking it up to the ebrake.</TD></TR></TABLE>
ahh alright, ill try it out tomorrow.
I usually just ground it instead of hooking it up to the ebrake.</TD></TR></TABLE>ahh alright, ill try it out tomorrow.
i also hooked up the red to the battery for constant power but it still turns off when i turn off the ignition?
Does my problem have something to do with the 2ignition? What is the second "ON" wire that the blue is suppose to connect to instead of the yellow. Since green is black/yellow...so instead of yellow, blue is...?
thats what u get turboing,speacially that motor,buy a b16 and vortec supercharger and u wont have that problem u will have a 272 hp reliable gas saving hot rod wooping,8k rpm revving,vtec slamming,short geard,monster for cheap lol jp
bump for a chump
<U>audio color codes</U>
red = ignition
yellow/black(usually plain yellow) = constant power
dont know if its the same for your turbo thingy but i just thought i throw it out there
red = ignition
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88HaveFun »</TD></TR><TR><TD CLASS="quote">bump for a chump
red = ignition
hmm...
red = ignition
hmm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 12:37 PM 6/22/2005 »</TD></TR><TR><TD CLASS="quote">bump bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 2:43 PM 6/22/2005 »</TD></TR><TR><TD CLASS="quote">43rwwfdssddf</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 3:12 PM 6/22/2005 »</TD></TR><TR><TD CLASS="quote">3232wefwefwfewfwrefe</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 4:34 PM 6/22/2005 »</TD></TR><TR><TD CLASS="quote">23r23ewfewfewf</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 8:14 PM 6/22/2005 »</TD></TR><TR><TD CLASS="quote">23r23sdfwfwe</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 1:15 AM 6/23/2005 »</TD></TR><TR><TD CLASS="quote">32r23rfwsfdsdfw</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 6:20 PM 6/23/2005 »</TD></TR><TR><TD CLASS="quote">23f323232f</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 7:35 PM 6/23/2005 »</TD></TR><TR><TD CLASS="quote">32232r32r32332rr3</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 @ 5:10 AM 6/24/2005 »</TD></TR><TR><TD CLASS="quote">23r2332wed2w3f3f</TD></TR></TABLE>
Dude, you need to chill with the bumps. People will reply. If you keep it up, this thread is going to get locked.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithv »</TD></TR><TR><TD CLASS="quote">
Dude, you need to chill with the bumps. People will reply. If you keep it up, this thread is going to get locked.</TD></TR></TABLE>
ok
ok
sporkcrx
Jun 18, 2002 01:28 PM
b18tdelsol
Jun 7, 2002 12:47 PM
