88 crx si problems!
as the title states i have a crx and when whenever i am turning rather quickly its want to bog down on me and then i have to rev it back up to take off. it just started doing it. was wondering if anybody had any suggestions to why it was doing this?
half the time im in 2nd gear and it just boggs down it even does it in 1st gear if you turn and a stop light. its takes off fine and then when you get half way through the turn it just boggs down
it happen usually on tight left hand turns, and there has been times when it has did it on a full tank but usually only when i get to about half tank
I have to have my 88 si above 1/2 tank when I'm autocrossing or it will do the same thing. The pickup in the fuel tank isn't situated in the ideal place.
Yep you hit it. The fuel pump pick up is more than likely on the left side( im a dsm'er give me a break
) and thats why the turns it wont pick up fuel and grab nothing for a second. Happened in my 1g dsm
