Ecu Test harness. How do I get around not using it.
Old Jun 21, 2005 | 08:45 PM
vtecn8ive's Avatar
Default Ecu Test harness. How do I get around not using it.
Well I am having problems with my 90 CRX Si with a mini-me swap (still obd0). I am getting code 20 which is ELD (electric load detected).
I have troubleshooted it all the way to where it says to use a ecu test harness but I don't have money for that. Is there a way to get around it and still follow the procedures in the manual?
-Shane
thanks.
Old Jun 22, 2005 | 03:38 AM
vtecn8ive's Avatar
Default Re: Ecu Test harness. How do I get around not using it. (vtecn8ive)
bump need to know today!!!
Old Jun 22, 2005 | 04:04 AM
EE_Chris's Avatar
You can either de-pin that particular wire from the ECU socket or just clip it, do your measurement and then re-solder back together.
Old Jun 22, 2005 | 08:21 AM
vtecn8ive's Avatar
Default Re: Ecu Test harness. How do I get around not using it. (EE_Chris)
Is it possible to use long needle (for the DVOM) adapter to reach in the pin holes with out taking them out?
-Shane
Old Jun 22, 2005 | 08:59 AM
JimBlake's Avatar
Yeah, if the pin is thin enough. Most procedures you don't need to disconnect that wire. But when you do you'll have to do it like Chris says.
holmesnmanny
Dec 18, 2011 12:51 PM
ayavner
May 28, 2008 07:20 PM
Dingo68
Mar 25, 2007 05:32 PM
USDM 4G VTEC
Apr 9, 2003 07:34 PM
_Endless_
Aug 28, 2002 06:10 PM
