over 5,000rpm needle jumps
Old Jun 21, 2005 | 07:40 PM
eg4door's Avatar
Default over 5,000rpm needle jumps
Ok when I go over 5000rpm the needle jumps all over. My coil and ingitor are new. Any ideas?
Old Jun 21, 2005 | 08:27 PM
B and B's Avatar
Loved
Community Favorite
Default Re: over 5,000rpm needle jumps (eg4door)
Re-check your connections inside the dizzy. Mine was doing this AND mis-firing.
A connector was slipped on with the spade just inside the connector boot instead of inside the female part of the terminal.
Revved happily after connecting
Was it doing this before the new parts? Were they replaced trying to fix this?
Old Jun 21, 2005 | 08:31 PM
HATCHingMN's Avatar
are you sure your clutch is not slipping???
Old Jun 21, 2005 | 10:09 PM
eg4door's Avatar
Default Re: over 5,000rpm needle jumps (HATCHingMN)
I tried changing the parts because I was told that could be it. Everything looks good in the dizzy, I don't know what else to check. It's not the clutch because it would slip making the rpm raise fast and not jumping back and forth.
Old Jun 22, 2005 | 05:32 AM
eg4door's Avatar
ANy other ideas?
Old Jun 22, 2005 | 05:44 AM
CRXified's Avatar
i had the same proble last week, my tach was jumping all over the place and missing, then it would die sometimes and i would have to tow it home then sometimes it would fire right up. i had a remanufactured dizzy from dizzy king and their IGNITORS are **** and i replaced mine with 1 from my old CRX i had lying around and it works A-1.
something i learned personally, and poeple on here said it wouldnt work was that ALL ignitors for all dizzys are compatible OBD0-OBD2. u just have to change the mounting heat sink on it. ill find the link on how to do it.
Old Jun 22, 2005 | 05:45 AM
CRXified's Avatar
Default Re: over 5,000rpm needle jumps (CRXified)
here ya go
http://www.markl.f9.co.uk/howt...y.htm
hope it helps
Old Jun 22, 2005 | 05:53 AM
JDM-EJ1's Avatar
I believe there is a blue wire in your dizzy that is for tach.. Check the connection of that wire.
Old Jun 22, 2005 | 05:56 AM
eg4door's Avatar
I changed the ignitor and still does it. It doesnt miss fire or anything. It drives fine just sometime at high rpm it jumps all over.
Old Jun 22, 2005 | 05:58 AM
CRXified's Avatar
aftermarket tach or stock? might be a bad cluster or something
Old Jun 22, 2005 | 06:01 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4door &raquo;</TD></TR><TR><TD CLASS="quote">I changed the ignitor and still does it. It doesnt miss fire or anything. It drives fine just sometime at high rpm it jumps all over. </TD></TR></TABLE>
When you say 'jumps all over' will it get up to 9,000 or something? Or does it stay in the 5,000 area?
Old Jun 22, 2005 | 06:17 AM
eg4door's Avatar
Default Re: over 5,000rpm needle jumps (JDM-EJ1)
it will jump from about 5000-7000 around that area.
JONESER
May 13, 2009 06:38 PM
Smash03
Jul 12, 2007 01:26 PM
saikouEF8
Jul 3, 2006 04:07 AM
I Have an STD
Jun 15, 2006 07:47 PM
George
Mar 11, 2002 06:45 AM
