help, did a compression test are these nubers right?
Old Jun 21, 2005 | 07:17 PM
greasemonkeys's Avatar
Default help, did a compression test are these nubers right?
alright my setup is a ls/vtec (a pr3 head and a b18a block) with Crower Stage 2 63042-2 cams duration at .050" 255 int and exh 248, and i have pct pistons. When I finished building the motor I did a compression test and it was around 190 for all cylinders are these numbers too low? the compression calculator says I should be a 13:1
Old Jun 21, 2005 | 07:26 PM
Kendall's Avatar
You did have the throttle open all the way when you tested right?
Old Jun 21, 2005 | 07:56 PM
snowseeker's Avatar
Default Re: help, did a compression test are these nubers right? (prodigysir)
Should be around 230 + for 13:1.
11:1 is around 190 - 200
Old Jun 21, 2005 | 08:57 PM
Default Re: help, did a compression test are these nubers right? (snowseeker)
thanks for the answers
Old Jun 21, 2005 | 09:04 PM
EG6R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowseeker &raquo;</TD></TR><TR><TD CLASS="quote">Should be around 230 + for 13:1.
11:1 is around 190 - 200</TD></TR></TABLE>
Really? I thought there wasnt a direct relation with the two. What formula did you use?
Old Jun 21, 2005 | 09:10 PM
snowseeker's Avatar
Default Re: help, did a compression test are these nubers right? (EG6R)
Its just a rough estimate going off of CR. I have a small chart that gives an average range of psi for CR's.
Old Jun 21, 2005 | 09:19 PM
snowseeker's Avatar
I went out and took a look at the chart again to make sure. It goes up in 20 psi incriments.
CR----------------average psi
8.0:1------------140
9.0:1------------160
10.0:1-----------180
11.0:1-----------200
12.0:1-----------220
I am sure these can off with diffrent setups, valves, chamber work, head gaskets, ect. They have always been pretty close for me. It is just a base to go off of.
dbiker207
Nov 26, 2006 07:10 AM
pootie.teng
Jun 2, 2005 10:32 PM
snowblind7x
Apr 13, 2005 08:12 PM
luckypon7
Mar 16, 2005 08:52 AM
