car starts then dies right away.....
Old Jun 21, 2005 | 06:14 PM
xd69's Avatar
Default car starts then dies right away.....
my car has trouble starting up. when it does start up it dies after about 1 minute. my rpms just fall down even if i give it gas. i start it bakc up and it will run for a little bit again and then just die. could it be my dizzy???
Old Jun 21, 2005 | 10:27 PM
coupe_hybrid's Avatar
Default Re: car starts then dies right away..... (xd69)
yeah could be your coil that's crapping out on you take the coil out and look to see if there is any sign of erosion or burns.
Old Jun 21, 2005 | 10:53 PM
Jimmy's Avatar
Global Moderator
do you have a CEL?
Old Jun 22, 2005 | 12:32 AM
xd69's Avatar
Default Re: (Jimmy)
yea it's throwing a code 14(iacv). that's the only code that it throws
Old Jun 22, 2005 | 12:37 AM
turboekcivic's Avatar
Default Re: (xd69)
its ur iacv it mite be messed up..
Old Jun 22, 2005 | 12:41 AM
BS 22's Avatar
Default Re: (xd69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xd69 &raquo;</TD></TR><TR><TD CLASS="quote">yea it's throwing a code 14(iacv). that's the only code that it throws</TD></TR></TABLE>
hmm not sure but maybe it needs to be cleaned??
here's a good write up on how to clean it:
http://www.superhonda.com/foru...44463
Old Jun 22, 2005 | 12:48 AM
_Cyclone_'s Avatar
Default Re: (turboekcivic)
Clean all the ports in your throttle body really good, clean the IACV, report back. I'll let you know what you can do next if this doesn't work.
Old Jun 22, 2005 | 09:27 AM
xd69's Avatar
Default Re: (CycloneBlue_1.6EL)
actually i just cleaned my iacv no more than a week ago. im thinking that it might be my dizzy. when i drive the car(when it used to run) my rpm needle would start to jump all over the place. even now when i just rev it, after 3k the needle starts to jump again. what do you guys think??
Old Jun 22, 2005 | 11:10 AM
05em2's Avatar
Default Re: (xd69)
it's something do with spark...so yeah dizzy, wires, and plugs ...i got my new dizzy for 200$ plus my old dizzy at autozone, they got rebuilt ones...works perfect...
if ur wires are not transferring spark ur car will jerk...if ur plannin on buying some get aftermarket ones might as well cuz they are cheaper than oem at honda and thicker....try msd ignition
Old Jun 22, 2005 | 12:51 PM
xd69's Avatar
Default Re: (Jay-Dee-Em)
i checked and i have spark. for a jdm engine with internal coil, can i get any honda dizzy with internal coil?? arent all honda internal parts the same?? im thinking of just getting a rebuilt one. the place where ama get the rebuilt dizzy from is this mexican shop that rebuilts dizzies.
Old Jun 22, 2005 | 12:56 PM
xd69's Avatar
Default Re: (xd69)
oh, and i new ngk wires too
VAAJ
36
May 7, 2009 07:35 PM
Boarderx192
Dec 13, 2006 05:42 AM
2poor2tune
Nov 10, 2006 04:24 PM
2point2
Apr 28, 2004 05:51 AM
EKtypeRhaTcH
Jul 9, 2003 11:37 AM
